Installed the bottle heater tonight.
Old Oct 19, 2002 | 02:11 AM
scorp508's Avatar
scorp508
Default Installed the bottle heater tonight.
Wiring was very straight forward. Bottle seemed to stay a nice 950psi while driving. The toggle switch is on switched 12v so there is no way for the heater to be on with the car off (unless the switch fails). Also the NX heater relies on a pressure sensor (turns on if <900 and stays on until 1050), so if the bottle is closed and there is no pressure in the lines (I purge the lines when I turn the car off) it will not turn on either.
