hesitation
If you're getting ping, check the plug heat range, check the EGR system and go to a lower t-stat. Also check your knock sensor as you shouldn't be able to hear ping, the ECM should pull timing first.
By | 2026-04-03 00:00:00
By | 2026-05-20 07:23:03
By | 2026-05-12 16:54:12
By | 2026-05-11 09:50:51
By | 2026-05-05 11:58:09
By | 2026-05-04 20:03:36
By | 2026-05-04 13:56:44
By | 2026-04-30 12:41:15
By | 2026-04-29 17:02:16
By | 2026-04-22 10:08:58
