AFR Hydra-Rev kit?
Old Oct 19, 2002 | 08:51 AM
ELEVENS's Avatar
ELEVENS
Default AFR Hydra-Rev kit?
Will be doing a cam swap shortly, and am considering the AFR Hydra-Rev kit to squeeze a couple hundred more RPM, and to keep the lifters from lifting off the lobe.
I'm looking for some feedback from anyone running these, and would also like to know if they can be installed on an L98 without removing the heads.
Thank you!
Old Oct 19, 2002 | 09:53 AM
BBA's Avatar
BBA
Default Re: AFR Hydra-Rev kit? (ELEVENS)
I used to run a rev kit on my 383. It's a great addition. You will get much better high rpm power from using it. You can even go more aggressive on the cam with smaller valve springs.
You have to have the heads on to install it in the first place, just the intake has to be removed, which is good because you should siameese the lower intake passages anyway if you want high rpm power. The combined effect should let your L98 with a stock cam pull hard to 5700-6000 RPM with no problems.
Old Oct 19, 2002 | 05:54 PM
ELEVENS's Avatar
ELEVENS
Default Re: AFR Hydra-Rev kit? (BBA)
Thanks for that, BBA. I searched the forum for old threads, and found one on the hydra-rev kit. The consensus is that it doesn't hurt, and many users really like it. Looks like I'll order one on Monday.
Old Oct 19, 2002 | 06:13 PM
MrNuke's Avatar
MrNuke
WTF is a hydra rev kit? :D
Old Oct 19, 2002 | 06:23 PM
ELEVENS's Avatar
ELEVENS
Default Re: AFR Hydra-Rev kit? (MrNuke)
Mr. Nuke, you speak FRENCH! :eek: It's a $229 spring-gadget that keeps your lifters from lifting off of the cam lobes at high RPM. Check this link:
http://www.airflowresearch.com/pages/hydra_rev.htm
Old Oct 20, 2002 | 04:32 AM
88-406's Avatar
88-406
St. Jude Donor '05
Elevens
I use the AFR kit myself on my 383. I haven't had any problems with it! The only thing bad I've heard is that the aluminum kits could/possibly produce metal flakes due to galing by the spring moving around.
I've heard that someone makes a steel kit that is said not to have this problem.
KM
Old Oct 20, 2002 | 06:28 AM
hngacurv's Avatar
hngacurv
Default Re: AFR Hydra-Rev kit? (88-406)
Any idea on what this would do on a basically stock L98?
Old Oct 20, 2002 | 01:13 PM
88-406's Avatar
88-406
St. Jude Donor '05
Default Re: AFR Hydra-Rev kit? (castivers)
A stock L98 wont rev high enough to take advantage of a Rev-kit. It will however benefit from the extra protection they offer.
KM
To AFR Hydra-Rev kit?
