c4 headlights issue- how to test between module and switch?
Old Jul 7, 2018 | 02:39 PM
qwiketz's Avatar
qwiketz
well finally broke down and ordered a replacement switch of ebay for $70. I'm hopeful that this works since I'm pretty much to the end of testing per the manual. I'll keep you posted!
Old Jul 12, 2018 | 12:55 AM
qwiketz's Avatar
qwiketz
Hi guys. Ordered a replacement switch and it did the trick. The only problem now is one of them won’t go up more than halfway. I “rebuilt” the motors with new plastic parts; not sure if I missed something or not
Old Jul 12, 2018 | 07:16 AM
JasBass's Avatar
JasBass
Can you manually rotate it through it's full range? And can you hear the motor keep turning once it gets to that point? I think your next move is to determine if it is stopping because of resistance or gear slippage.
Old Jul 12, 2018 | 06:42 PM
qwiketz's Avatar
qwiketz
I'm going to play with it a little more tonight. I saw an old thread on the forum where a member's did the same thing and the fusible link was bad/going bad. There are a few different things for me to try on this one.
Old Jul 12, 2018 | 07:15 PM
JasBass's Avatar
JasBass
lol, that was probably my thread. I had a bad fusible link that fixed up my issue. Let us know man
Old Jul 16, 2018 | 10:32 PM
qwiketz's Avatar
qwiketz
any chance that after my rebuild of the motors that the linkage is binding? The motor wheel spins as the unit is moving from position to position and then aburptly stops 1/2 up. Turn the light off and it works fine.
You can hear the right motor working for several seconds after the left one. The left one just stops and goes silent half way up.
Old Jul 17, 2018 | 07:25 AM
JasBass's Avatar
JasBass
Manually rotate the motor to feel if it is binding or not first. If it is not binding, then we can go down the gear/electric road
Old Jul 17, 2018 | 10:37 AM
qwiketz's Avatar
qwiketz
well, that was easy. I rotated it and the top **** spins fairly freely up until the light is half way up. At that point it gets super tight to the point that I cant turn it by hand. Time to diagnose that problem.
On a better note, for the past 5 years my right window would not roll down. I swapped out the switch while working preparing to do the window sweep and that fixed it.
Old Jul 18, 2018 | 07:23 AM
JasBass's Avatar
JasBass
Good find. So now the question becomes, is it binding in the framework or is it binding in the gear housing. I'd start with the housing framework first. If the framework isn't binding, then we have to go down the motor gear road
Old Jul 19, 2018 | 01:00 AM
qwiketz's Avatar
qwiketz
found my culprit. It is the silver part of the arm in the middle. When I rebuilt the motor I must not have reinstalled the linkage correctly.
There’s a little play so maybe I missed a spacer?
Old Jul 19, 2018 | 07:36 AM
JasBass's Avatar
JasBass
There should be a little play in the framework; there is on mine at least. Are you sure it is super binding up there? A light shot of oil can help diagnose as well. I'll send pics from mine later this evening to confirm rebuild was done correctly if you think that will help?
Old Jul 19, 2018 | 11:00 AM
qwiketz's Avatar
qwiketz
Well I believe I figured it out. After further inspection it looks like my metal silver bracket that acts as a stop is clocked 90’ out of whack. So the range of motion of the light is 90’ off. Looks like I made a mistake during reassembly.
Looks like i me I have a project for this weekend!
Old Jul 19, 2018 | 10:13 PM
  #33
JasBass's Avatar
JasBass
Lol I hear ya on the weekend projects. Interesting issue though. I’ll have to keep that in mind if I ever have to rebuild mine. Let us know if that ultimately fixes it
Old Jul 20, 2018 | 12:38 AM
  #34
qwiketz's Avatar
qwiketz
btw, good to see that you're working on your c4 as well! Not too many of us at this point.
Old Jul 22, 2018 | 10:25 AM
  #35
qwiketz's Avatar
qwiketz
Hi guys. Much eAsier to do the 3dd time around! I now have it working but I’m going to have to keep an eye on the headlight linkage. I’m not sure if a little play caused the silver bracket to slip 90’ out or not. It seems okay upon reassembly and I did test it and they both now work. Hopefully it stays that way!
