throttle body cooling ?
Old Jun 9, 2018 | 12:42 PM
dozerman1's Avatar
dozerman1
Default throttle body cooling ?
Another problem !!!
I just removed the throttle body. The lower coolant hose is still connected and the vacuum line at the bottom is disconnected. Is it ok to just remove this hose and plug the hole in the intake? And is the vacuum supposed to be hooked up to the tb?
Old Jun 9, 2018 | 01:17 PM
playsdixie's Avatar
playsdixie
depends on where you live....you'll need them in Alaska....
Old Jun 9, 2018 | 02:01 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
First thing I did with this '88 and the prior one was the TB coolant bypass mod.
Check front of your radiator for debris collection, check radiator for proper coolant flow & pressure, replace the T-stat. I don't like the engine running in to 200+deg. temp range, so have always (for >17yrs) run a 160 deg. T-stat.
Old Jun 9, 2018 | 02:16 PM
dozerman1's Avatar
dozerman1
South Texas
Old Jun 9, 2018 | 02:18 PM
dozerman1's Avatar
dozerman1
That's what I needed to know.... I'm going to pull the radiator next and check it out... the temp runs as far up as 240 with the a/c on... when it does that I have to shut the a/c off and it will cool down some .It just depends on how hot it is out side....
Old Jun 9, 2018 | 02:19 PM
Bfenty's Avatar
Bfenty
2017 C4 of Year Finalist
Originally Posted by dozerman1
South Texas
it's not hurting anything. clean your radiator, that's almost certainly all you need to keep from overheating.
Old Jun 9, 2018 | 02:38 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Read Bfenty's PSA on summer cooling.
BTW...240 is not THAT crazy of a number but it should go lower. Again, clean your radiator and look for debris BETWEEN the AC condensor and the radiator.
Old Jun 9, 2018 | 05:33 PM
playsdixie's Avatar
playsdixie
I'm in S Florida....I don't see 200 with the a/c on in traffic...so somethings not right....I do have a lower t stat.....
Old Jun 9, 2018 | 06:20 PM
dozerman1's Avatar
dozerman1
My thermo is a 165, guess next option is pulling the radiator...
Old Jun 9, 2018 | 10:25 PM
Benny42's Avatar
Benny42
Fill in your profile. What year is your car. The fan turn temp is 235* +- a few. 240* is pretty warm but not "turn off the A/C" hot. Do clean between the rad & a/c condenser and report back.
Old Jun 9, 2018 | 11:03 PM
belairbrian's Avatar
belairbrian
For some reason no one mentioned that the coolant flows through the throttle body to warm it in cold weather, not to cool it in warm weather.
That's why so many people bypass it. Not really needed a lot of places.
Old Jun 10, 2018 | 01:10 AM
dozerman1's Avatar
dozerman1
It is a 1989 I have the fan set to bypass the ECM. It has separate wiring and comes on at 190 and doesn't shut off until 180. The fan is an aftermarket fan that produces about 2500 cfm...
Old Jun 10, 2018 | 08:46 AM
Bfenty's Avatar
Bfenty
that's...a lot. You shouldn't see 230 with a fan like that. my stock fan comes on and instantly I see cooling even in 90+ degree weather. Again, cleaning your radiator is probably the best solution. It's not terribly hard to remove but even if you don't want to remove the radiator, removing the shroud and using a pressure washer/compressed air on the area in between the condenser and radiator with go a long way. You should also blast it from inside the engine compartment to dislodge the crap that gets stuck in the radiator itself (it's amazing how much gets stuck in the fins). Be careful not to bend them.
Old Jun 11, 2018 | 11:14 AM
vader86's Avatar
vader86
Correct.
Old Jun 15, 2018 | 11:29 AM
dozerman1's Avatar
dozerman1
depends on where you live....you'll need them in alaska....:d
asking a new qquestion
Old Jun 15, 2018 | 11:31 AM
dozerman1's Avatar
dozerman1
Originally Posted by 65z01
first thing i did with this '88 and the prior one was the tb coolant bypass mod.
Check front of your radiator for debris collection, check radiator for proper coolant flow & pressure, replace the t-stat. I don't like the engine running in to 200+deg. Temp range, so have always (for >17yrs) run a 160 deg. T-stat.
new question......
Old Jun 15, 2018 | 11:35 AM
dozerman1's Avatar
dozerman1
Originally Posted by bfenty
that's...a lot. You shouldn't see 230 with a fan like that. My stock fan comes on and instantly i see cooling even in 90+ degree weather. Again, cleaning your radiator is probably the best solution. It's not terribly hard to remove but even if you don't want to remove the radiator, removing the shroud and using a pressure washer/compressed air on the area in between the condenser and radiator with go a long way. You should also blast it from inside the engine compartment to dislodge the crap that gets stuck in the radiator itself (it's amazing how much gets stuck in the fins). Be careful not to bend them.
ck out new question. And btw, how do i open a new post?
Old Jun 15, 2018 | 02:07 PM
playsdixie's Avatar
playsdixie
there's a tab top left of your home screen...wondering why you need a new one as you have some really knowledgeable guys on this thread trying to assist you...any question you have will go back to those guys.....
To throttle body cooling ?
