Long Slow smooth shifts between gears
Old Jun 11, 2018 | 05:45 PM
joshualee's Avatar
joshualee
Default Long Slow smooth shifts between gears
My 1987 automatic shifts very slow between gears when im not stomping on it. When I stomp on it it shifts quickly. Is this normal? Feels smooth but seems old it take a a few seconds to shift.
Old Jun 11, 2018 | 09:36 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Shifting slow or fast is a matter of interpretation. This sounds pretty normal as a normal shift is smoother and a brisk acceleration will yield a quicker shift.
Old Jun 11, 2018 | 09:51 PM
383vett's Avatar
383vett
Is the tv cable adjusted properly?
Old Jun 11, 2018 | 11:45 PM
confab's Avatar
confab
Probably normal. Check your TV adjustment just for kicks.
But as you accelerate, TV pressure rises and the shift schedule moves higher and harder.
Old Jun 12, 2018 | 12:59 AM
joshualee's Avatar
joshualee
Thanks guys. Great forum for a new vette owner. I'm learning a lot. I'll try and take a look at the tv cable and reset it when I'm done work.
Old Jun 12, 2018 | 01:03 AM
joshualee's Avatar
joshualee
But for the record, it doesn't feel bad, just not something I'm used to. I'm sure it's ok but I had to ask since my tranny won't go into first gear with the shifter so I'm looking at all options. First works but I just can't select it and have it stay in first. Shifts into second every time.
Old Jun 12, 2018 | 06:34 AM
cv67's Avatar
cv67
St. Jude Donor '05
If youre manually shifting it make sure the boot isnt hanging it up from dropping down. Definitely do the TV cable adjustment. If its off it can shorten the life. It shouldnt lag seconds in betweeen shifting.
Old Jun 12, 2018 | 02:22 PM
joshualee's Avatar
joshualee
Adjusted tv cable and now it's much better. Thanks everyone. Hope it didn't do any damage being the way it was.
To Long Slow smooth shifts between gears
