Injector question?
Old Jun 13, 2018 | 11:07 AM
JBJrC4's Avatar
JBJrC4
Default Injector question?
Is it required to have an adjustable fuel pressure regulator with 22lb Bosch 3s on a stock 91 L98? Or can I keep the stock fuel pressure regulator?
Old Jun 13, 2018 | 11:32 AM
Kevova's Avatar
Kevova
The stock regulator should be ok.
Old Jun 13, 2018 | 11:17 PM
aklim's Avatar
aklim
Unless you run out of injector and have the ECM tuned for it, I would just stick to the stock regulator. I heard the theories of better atomization with higher pressure but I am not aware of tests that prove the gains are significant under street conditions. Sure, if you were racing for a living, I'd push anything that gets me a thousandths of a second.
Old Jun 14, 2018 | 11:22 PM
JBJrC4's Avatar
JBJrC4
Nothing like that just want it to run like it did from the factory. I'm replacing the Bosch 3 yellow/orange injectors with the grey Bosch 3 22lb. I'm receiving them tomorrow. Just wanted to know if I could keep the stock regulator.
Old Jun 15, 2018 | 08:12 AM
aklim's Avatar
aklim
You could but I'd change it just to be sure. The rubber diaphragm is old.
Old Jun 15, 2018 | 08:14 AM
vader86's Avatar
vader86
Yes you can run the stock one.
To Injector question?
