Wheres my hp ????????
Don't take the actual values of the air fuel ratio too seriously. The wideband O2 reading was taken at the tail pipe so the cats are throwing off the real reading. Notice the rather drastic change in air fuel from one run to the next. The higher one (13.2) is the second run. I suspect its higher because the cats heated up during the first run. An SS Camaro had showed the a similar kind of change from one run to the next.
I had a loose coil wire which I did not discover until I got home which caused a sneeze during the second run.
I don't think there is any problem with fuel delivery since there is no dramatic drop off at any point and the reading is not way lean. The only places I can think of where the problem might be is spark knock, bad wires (which I am changing) or plugged cats.
Any suggestions would be appreciated.
[Modified by AquaMetallic94LT1, 11:16 PM 10/19/2002]
In any case, what are you running for exhaust? If those are stock cats on stock manifolds that is probably your trouble. A friend of mine just dyno'd yesterday. He has a 383 with what I'm pretty sure is an identical cam, 383, pocket ported stock heads, etc. The major difference would be that he runs long tubes and no cats into a set of very high flow mufflers. He made 369 hp and 379 torque.
Looks like you made 345 hp, 331 torque. When I added long tubes and mufflers to my car I picked up 23 hp and 32 pounds of torque (on stock heads), that would put you at 368 and 363, if you consider that a stroker with better than stock heads would see more benefit than a 350 with stock heads, that should put your numbers right up there with that of my friend.
So if you're running through stock exhaust, that's your whole trouble. The engine is an air pump and you've got to be able to get the air out of it just as well as you get it in. If you've already got some long tubes then I don't know what to tell you. Cat's alone shouldn't cost you that much hp.
:cheers:
Also if that wire was causing you to have a weak spark, it could be accounting for some power too.
:cheers:
I also agree with ski, you gotta take that motor up to at least 6500rpm to find the top of your hp curve.
Bruce
93LT1 Conv w/ZF6
Blown D1-SC/N2O
ARE built 383ci/Stage II heads
89vette is getting 430 hp at the crank from his stepup. He's got a superram so his power peak power is in the upper 5K range. He's got long tubes also.
I thought lingenfelter was getting about 440 from his 219 cam superram LT1s with stock LT1 exhaust.
I was expecting about 450 - 470 peak crank hp with this setup. I have the right heads and cam specs for the job. I can't figure out what is missing other than exhuast. The fuel air is set at 12.5:1 at WOT above 3500 and the spark is set at 38 deg at full throttle. Some of the tuners like more are advertising a lot more hp with similar setups.
I am limiting the upper rpm to 6300 because the block has 2 bolt mains.
I desktop dynoed this setup and it predicts 487 hp with headers and full exhaust.
:confused:
[Modified by AquaMetallic94LT1, 2:51 PM 10/20/2002]
BTW, that is where your horsepower went. :cheers:
Based on the torque curve I think I have too much cam. I'd like to advance the cam but can't do it with an LT1 distributor.
I've since had the exhaust redone to get rid of both cats, one is gutted, and I have 3" all the way back, and it feels much faster now, also louder. I also found a vacuum hose that wasn't hooked up, and 1 burned plug wire.
Just this weekend, a guy with a LT1 350, 11:1 comp, 232-242 hydraulic cam, cnc ported LT1 heads and hooker longtubes going all the way back with 3" pipe on both sides dynoed 399 rwhp.
I'm thinking about switching to the longtubes also. I'm off about 80 rwhp than I think I should be right now. Don't think I'll pick up that much power with the exhaust change, but when I go back to dyno, I'll uncap the exhaust at the headers to see what it's robbing from me.
Keep us posted on what you find out.
I also happen to know that nobody got a printout from the dyno. If you would like your printout or the run files, I'll send them to you, I've got them all. I got to salvage our dyno information before the dyno was sold. :cheers:
Hmm, I was looking and I don't see your numbers. You didn't dyno Saturday did you? In any case I'll throw out Jessie's graph, looks like this
He's got a nasty mid RPM thing going on that he needs to figure out, but other than that it looks really healthy. Here's by cheap shot BTW, those are TEA lT1 heads with stock valves he's running, they actually flowed a little less than mine because of the stock valves. I feel confident he'd be over 400 with my heads, or if I had his cam. We may tune it to over 400 yet, his A/F is a little lean on the top end.
And just wait until he gets that nitrous system working!
[Modified by Nathan Plemons, 6:59 PM 10/21/2002]
The point is, even with 33 cubes less, and 30 cfm less on airflow, he made 50 more rwhp than my 383. I'm going back to the dyno today to uncork the exhaust to see if that is what's holding me back. The y-pipe is 2.5 inch outside diameter, so I'm guessing that it's 2.25 inch inside. Jessie has 3" all the way back with no bends, and I'm wondering if that's my problem.
I do know that when he had "Riggs Racing" heads he dyno'd fairly poorly and he picked up 15 hp by opening up his cut out. Do you happen to know if these numbers were through his muffler or using his cut out?
I hope it's the exhaust, and nothing else.
If exhaust alone fixes your problem than that would be a great asset to be able to throw up both numbers for comparison sake. That sort of thing tends to really drive the point home for some people who just refuse to accept it otherwise.
Your correct about the car failing emissions. Just for grins, I took it through the Oregon DEQ testing a couple days ago. It passed the NOX part but failed the HC (what a shock) and just barely failed the CO. The relevant numbers were:
2.3 g/mile HC (1.2 g/mile is the limit) and 30.8 g/mile CO (30.0) is the limit for that one.
We have full IM240 emissions inspections here so getting rid of the Cats is not an option. I suspected the cam wasn't going to pass so my plan for that has been to put on 1.3:1 break in rockers from comp cams for inspection purposes. I have been debating between those and a smaller cam since the peak power is so far up in the rpm. I was expecting the peak to be around 6000.
Do they offer a show car emissions waiver in your area????
