help - loss of power in '85
#81
excellent thanks everyone -
#82
they will fit fine.
on my iron heads, (u have ironhead if stock) i dont use anti seize and i always torque to spec. if u dont have a torque wrench just dont strip the threads.
on my aluminum head (87) i use a small wipe of anti seize. metal to aluminum can seriously bind with minimal corrosion.
ive used dielectric off and on and i dont know if it helps.
When I went to do plugs on my 78 LTD, I found out why dialectic grease is used - a plug had corroded itself to the wire, to the point pliers wouldn't separate them. They were original plugs and wires, so no big loss, but getting the plug out was awkward using a wrench with the wire flopping all over the place.
#83
2017 C4 of Year Finalist
yes updated to .35
man. ive done plugs on my car many times and i still find the passenger side frustrating as heck. if u insist on doing plug checks before cap/rotor checks, here are some helpful tips im sure others have even better tips to add: . #2, you may find that you can straight shot in with a long enough extension to reach the plug from the wheel side of the well, my 85 i couldnt, my 86 and 87 i can. no idea why the difference. for 4 and 6, i find i turn around and face away from car and reach in with "feel" for the plugs hole. ive always found putting the plug into the socket with the rubber retainer is easiest and i may need a small extension or wobly to hold in my hand to guid it into the threads. i wiggle wiggle the plug to get it started while turning.
if u pull off the cap first to check for grenaded rotor/cap and its fine, might as well leave it off until after the plugs are individually checked because if plugs are good, you will likely end up putting in a new icm under the cap.
good luck, were rooting for u.
#84
rotor and cap looked fine - I did not see any signs of burns or breakage I did replace the cap and rotor - nonetheless - just to check it off the list
side note while in there I re-taped and replaced oil sending units to stop an annoying leak hopefully
any tips for the plugs and wires - it took about 10 minutes just to get a wire off on the passengers side - I have thought about removing the air pump emissions stuff maybe more so now
I have extensions and elbows the turn and twist but I cannot get any movement
any suggestions?
any suggestions?
#85
any suggestions?
any suggestions?
The plugs are fairly easy to remove with stock headers. Get your deep well spark plug socket, find the plug by hand, then get the socket on. If you have long arms, you can do this kneeling down. If you have short arms, you could take a tire off and get a little closer. You can also just hunch over the side of the car. Once the socket is on, grab a ratchet, and your set of extensions. Find an extension that will get you enough clearance, then take the plug out. For the drivers side, I used a 3in extension, two of the passenger side plugs needed a 2in extension, and I could only get 1/8 turn on the ratchet, but that's all it takes.
#86
any suggestions?
any suggestions?
#87
sorry about all that - that was just I don't know what to call that - it was tight and traditional what I had was not working - so I found 3/4 open end and spark socket that and an offset 19mm box end wrench - and away we went - started on what to me was the more difficult side - passenger - driver side almost seemed too easy comparatively
#88
I will say that the emissions air pump stuff does not help any
#89
boy those were bigger than I thought they would be
plugs - to me anyhow - look pretty ugly
#90
almost forgot - I forgot to take a picture to show the difference in the plugs - the rapid fire are noticeably longer to the boot side - 1/4" or more
#91
I want to say an enormous THANK YOU to all that helped -if not for your patience with me and advice to be patient and methodical - and pointing me in the right direction each time - you guys nailed it. I just got back from a short ride to see how everything felt - that was fun - had a little pep in it's step
I realize I am not out of the woods entirely because looking at those plugs means something is not right on the inside - just not sure what and how much. I am sure I will be re-posting and asking about that soon enough
thanks again everyone
Sean
Sean
#92
did u find a plug with a crack in the porcelain?
#93
I will give them a closer look - I did not see one initially - I'll put on my other glasses so I can see a little closer
#94
I did not see any with evident cracks unless it is a hairline that would show up under heat and stress - if that makes any sense - the plugs were pretty wet with oil and the electrodes (center?). were almost non-existent - very skinny and small - could not speculate if they were gapped correctly or not
compared with what I just put in pretty big difference. - I will watch over the next few days of driving if it starts up again - then I will need to look at that control module you spoke of-
from the looks though there will need to be some internal work done - question is how soon before I need to?
#95
Sean
Sean
I'm glad that we solved the rough running!
sb66 (06-21-2018)
#96
yeah if its running great now it isnt the ignition control module.
i think ill change my plugs!!!
nice work getting to the bottom of it.
sb66 (06-22-2018)
#97
This sounds exactly like the issue I'm having-I'm getting oil into the cylinders (my plugs look JUST LIKE yours). Every couple thousand miles I've had to change plugs because they eventually foul and lead to running like crap. I'm also losing oil at about a quart per 500 miles. You may want to keep an eye on your oil level. I'm thinking it's bad valves seals but haven't had a chance to do the job yet. Could also be gaskets someplace. Anyway, all that to say it seems like your issue is nearly identical so those are things to start with.
sb66 (06-22-2018)
#98
thanks - valve stem seals was what I was thinking as well - but you know when you open it up you never know what you are going to find - and then you also may think what else can I afford to do while you're in there . . . .
thanks again everyone!
#99
Going with a couple others here. Worked yesterday and not today? Not likely compression/valves/ugly bad stuff. Sounds like fuel. When was the last time the fuel filter was changed? Could be a $20 problem.
