Running rich
Old Jun 18, 2018 | 09:53 PM
boceltics17's Avatar
boceltics17
Default Running rich
My 86 exhaust smells rich at idle. Additionally the cat recently failed. It is running fine since replacing tge cat. It has been modded, bigger cam, headers, runners, throttle body and a Hyperchip. All was done by a pro shop in Ca 20 years ago by the previous owner. It also has an adjustable fuel pressure regulator. If I were to back off the fuel pressure would this help at all? I am fairly handy but don't have a fuel pressure gauge. Any suggestions would be appreciated.
PS..in 2015 it had an issue where it was running rough and fouling plugs. A local shop chased their tail for quite a while. Replaced the coil, computer mass air, throttle body and intake gaskets before getting it close to back to normal. It has always seemed to running rich judging by the smell of the exhaust.
Old Jun 18, 2018 | 11:11 PM
Kevova's Avatar
Kevova
You need a scanner or something to read data.
Old Jun 19, 2018 | 07:13 AM
ex-x-fire's Avatar
ex-x-fire
Check the fuel pressure & bleed down rate, it should hold pressure after shut down.
Old Jun 19, 2018 | 07:35 AM
aklim's Avatar
aklim
Go to an Autozone and buy yourself a fuel pressure gauge. Go find yourself a scanner, be it a cable from 1320 electronics with the free ALDL Scan software for the Android or an actual scanner.
With the bigger cam and the HyperJunk, who knows what is happening. You might have to figure out what the cam was and get a tune done for the car and not some off shelf crap
Old Jun 20, 2018 | 05:36 AM
boceltics17
Does anyone burn custom ROMs anymore for these? I do have the specs on the cam.
Old Jun 20, 2018 | 07:32 AM
aklim's Avatar
aklim
Ask around the dyno shops. They might have the stuff to burn a custom chip for you. I'm kinda skeptical of the "Guess a Tune" people since none of them have said that they can't do a better job if it were on a dyno vs taking specs.
Old Jun 20, 2018 | 07:37 AM
Kevova's Avatar
Kevova
You will have to search TPIS , PCMOFNC there are more in house with dyno will be limited. You will need to make logs of data to have new proms made.
it's possible that it's not the prom, since you claim mods were done years ago. You may look for someone with more experience with tpi and obd1 to help you.
To Running rich
