Competition Cams 4808 Guidepaltes
Old Jun 22, 2018 | 08:25 PM
Carnivore's Avatar
Carnivore
Default Competition Cams 4808 Guidepaltes
I have an early 1990 Corvette coupe (L98 - 350ci). I purchased Corvette Rocker Arm Kit, 1.52 Ratio, Competition Cams, 1986Late-1995 Part # 25-104099-1 from Ecklers. Included in the kit are new 5/16 inch guideplates(Competition Cams 4808). The new guideplates bolt holes are slightly narrow for my heads and I cannot bolt both stud bolts in at the same time. The stock guideplates have a wider and shorter slot. Can I keep my stock guideplates? Any suggestions?
Update: I got the first Competition Cams 4808 guideplate bolted in. Started the bolts with the guideplate on the studs but backed off from the head. Very tight fit. Thx
Last edited by Carnivore; Jun 22, 2018 at 11:02 PM. Reason: Update for guideplate information
Old Jun 23, 2018 | 01:54 AM
383vett's Avatar
383vett
Sometimes guide plates might need slight dressing with a die grinder to fit perfectly.
Old Jun 23, 2018 | 01:56 AM
Pwnage1337's Avatar
Pwnage1337
Agreed. If it was mine, I'd grind them. Some people get a little leary grinding brand new ****, but that's part of the game of making it work
Old Jun 25, 2018 | 02:26 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The OEM guide plates were used only to roughly position the rods during assembly and so did not touch the rods during normal operation.
If your new rockers are not self-aligning then you need the new guide plates, else use the OEMs.
To Competition Cams 4808 Guidepaltes
