1987 Fuel Surge
Old Jul 4, 2018 | 12:38 AM
puzzigully's Avatar
puzzigully
Default 1987 Fuel Surge
Guys,
Has anyone experienced fuel surge (i.e. fuel moves away from the pickup in the tank) when the fuel level is 1/3 full or less?
I seem to get it as soon as fuel gets to or below 1/3 full and accelerate in a straight line.
The engine hesitates and breaks down, stumbling etc.
If its over 1/3 full, I never experience it
Interested if I'm not the only one and if anyone had modded the pickup to eliminate..
Old Jul 5, 2018 | 01:44 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
While drag racing I always arrived with 1/4-1/3 tank and had no issues even below 1/4 tank while pulling mid-1.8s short time.
I wonder if your pickup assy. has been distorted to not reach low enough.
Old Jul 5, 2018 | 04:13 AM
puzzigully's Avatar
puzzigully
Thanks for the input, I'll have to pull it out to take a look.....Unless Bubba has had his hand in it, cant see why it would be damaged/moved??
Old Jul 5, 2018 | 11:10 AM
383vett's Avatar
383vett
Never underestimate Bubba. The stock C4s didn't have this problem. After Bubba messed with things, the problem appeared.
Old Oct 31, 2019 | 07:29 PM
puzzigully's Avatar
puzzigully
Just to finish this off - I know it's taken a while.
But with the Callaway TT, there were two additional injectors added for increased fuel that the turbos necessitated.
Anyway, the injectors were clogged up and almost completely blocked.
Cleaned them up and all is good!
I had cleaned the 8 on the engine previously, BUT not these additional two.
Problem solved!
Old Nov 1, 2019 | 01:39 PM
Callaway Chris's Avatar
0Callaway Chris
Former Vendor
On the Callaway, one is to operate with at least 1/8 tank of fuel, always. You may experience fuel pick up problems at or below this level. Something other than what you had, but wanted mention, also.
Old Nov 4, 2019 | 02:09 AM
puzzigully's Avatar
puzzigully
Thanks Chris,
important information!
My issues were with (not surprisingly) tanks that were at least 1/2 full or more - but I'm thinking the tank level had very little to do with it now.
The condition of the injectors was pretty poor - amazing ANY fuel could get through!
As a matter of interest, do you know (generally speaking) if the two additional injectors add fuel all the time, or just at certain rpm/load/throttle position?
Old Nov 4, 2019 | 08:37 AM
0Callaway Chris
Former Vendor
The two addl. injectors only fire when under positive manifold pressure. So they are at rest, other times.
Even though the 87-88 injectors were different than the notorious 89-91 RP (Rochester Products) injectors, all benefit from replacement with a modern injector. I like the Delphi Injectors from FIC. Here's what I've been using in my own cars, and for customer suggestions:
https://fuelinjectorconnection.com/c...l-injector-set
Looks like they have a sale which may expire today.
Old Nov 18, 2019 | 12:19 AM
puzzigully's Avatar
puzzigully
Chris,
They are the std GM replacement injectors?
What do we replace the two additional ones with?
thanks
Old Nov 18, 2019 | 12:44 PM
DMITTZ's Avatar
DMITTZ
Yes, I've had this fuel slosh problem. Its frusterating and makes me want to do a custom baffled fuel tank or something one day.
Old Nov 18, 2019 | 01:05 PM
aklim's Avatar
aklim
I didn't detect anything resembling a slosh. I think it is because I have the baffle. Now if it were a race situation, I probably will want a tank with a purpose built baffle instead of the stock one. I always run till it is at empty and past reserve.
Old Nov 18, 2019 | 01:18 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
My Callaway TT needed a 1/4 of of tank. With almost 600rwtq...1st and 2nd gear(if I hooked) would move the fuel away from the pickup enough to make the engine lay down.
Old Nov 18, 2019 | 02:14 PM
0Callaway Chris
Former Vendor
Chris,
thanks
Use the 22lb Delphi injectors in the link - ON SALE NOW at FIC in the link provided. 20% discount.
The front two injectors have never gone bad in any cars I have seen. They should be fine.
To 1987 Fuel Surge
