New first time owner w/ an oil leak
Old 07-13-2018, 10:41 PM
Carla&Jim
6th Gear
Carla&Jim's Avatar
Default New first time owner w/ an oil leak
Hello, new member & first post. Bought an 1985 last week & have oil leaking near tune port injector at top of engine & pooling on manifold below
Old 07-13-2018, 11:02 PM
VikingTrad3r
Oil Producer
Support Corvetteforum!
VikingTrad3r's Avatar
Received 2,263 Likes on 1,447 Posts
it does look like oil.
is it really dirty coolant?
Old 07-14-2018, 12:39 AM
xrav22
xrav22's Avatar
You have to clean it and find out where it is coming from.
Old 07-14-2018, 12:43 AM
Carla&Jim
6th Gear
Carla&Jim's Avatar
It’s definitely oil, we’ve cleaned it daily but are unable to track where it’s actually leaking from. Every day there is new oil on the garage floor, it is 2 areas on the floor about 2-3 inches apart
Old 07-14-2018, 12:45 AM
Carla&Jim
6th Gear
Carla&Jim's Avatar
The oil is pooling on both sides of the manifold
Old 07-14-2018, 12:58 AM
xrav22
xrav22's Avatar
I would say clean it stat it and watch it, it is coming from somewhere. I just changed my intake gaskets last week because of a coolant leak, but I am trying to figure where oil could come from.
Weird.
Anyways in the middle are EGR passageways but it should be fumes passing not enough pressure to push oil thru. Not sure.
Old 07-14-2018, 01:05 AM
Carla&Jim
6th Gear
Carla&Jim's Avatar
Maybe a little back ground on the car, it was garage stored & hadn’t been driven for 2 years in Indiana, I flew up there from Florida last weekend to buy it & drive it down to Florida. I did get the oil changed & had it checked over prior to the long drive & I had the oil changed again after the 1300 mile trip. The car has 44,000 miles on it.
Old 07-14-2018, 07:36 AM
bjankuski
bjankuski's Avatar
Did you use sealant on the intake manifold bolts? It looks to me like the oil is from the bolt. You need to reseal that bolt. Pull it out add some sealant and you should have that fixed.
Benny42 (07-14-2018)
Old 07-14-2018, 07:49 AM
WW7
WW7's Avatar
The oil is most likely coming up the manifold bolt threads and pooling , this happens because the bolt didn't have sealer put on before installing it..The manifold bolts go through the head into the oil gallery , if you don't put sealer on the threads the internal pressure pushes oil up the bolt threads... You could try pulling the manifold bolt out and putting sealer on it, then retorque it to spec...WW
Old 07-14-2018, 07:54 AM
Carla&Jim
6th Gear
Carla&Jim's Avatar
Thanks for all the replies, we’re going to try sealing the bolts this morning & will give an update
Old 07-14-2018, 09:44 AM
WVZR-1
WVZR-1's Avatar
Received 2,262 Likes on 2,025 Posts
I was going to mention seeping bolts also but you mentioned service before you left and I'd assume you checked oil when getting fuel ... so how much oil used during trip after sitting? Did you 'stick it' before the last service after the trip? Stick said what?
Old 07-14-2018, 10:45 AM
VikingTrad3r
Oil Producer
permatex aviation form a gasket is what i use.
i typically dip the bottom third of the manifold bolts and let them sit for an hour before install but ive had the same succes just dipping and installing. the stuff is cheap and will last a lifetime.
Old 07-14-2018, 10:47 AM
VikingTrad3r
Oil Producer
dont over torque. 35 foot pounds.
Old 07-14-2018, 11:44 AM
Carla&Jim
6th Gear
Carla&Jim's Avatar
The stick showed pretty much the same during the trip & once I was home, maybe a slight difference but so minor it was basically the same level. Have checked oil everyday since getting it changed after the trip & again really no noticeable change in level
Old 07-14-2018, 01:33 PM
Benny42
Benny42's Avatar
That amount of oil is annoying as heck but you won't see those 2 tablespoons of oil loss on the dipstick. I agree with the others, seal the bolts and report back with good news. Nice looking low mile '85 you found. Score!
Old 07-14-2018, 01:45 PM
VikingTrad3r
Oil Producer
carla and jim did u upload pics of yhe car? we like those!!!
Old 07-14-2018, 02:37 PM
ctmccloskey
ctmccloskey's Avatar
Received 1,104 Likes on 876 Posts
Hello there,
Welcome to the crazy world of Corvettes! It is always good to have new blood buying these beautiful cars. Now starts the "Learning Phase" of your ownership. These 1984 up cars are a lot of fun and a great bang for the buck! I have a 1988 coupe and it is my second Corvette.
On an oil leak like yours at the very top of the engine makes me wonder if the PCV (Positive Crankcase Ventilation) valve has gone bad. When the PCV valve fails it frequently blocks the pressure that builds up inside the engine. If you get too much pressure it can actually force oil to leak in places that wouldn't otherwise. My Mother's Volvo PCV stopped working and while she was driving it blew out a seal and dumped all the oil causing the engine to seize.
Check your car to be sure that your engine has a clean path to blow out the pressure that builds up inside.
I wish you the very best with your "new" to you Corvette. I hope that you get many smiles per gallon!
To New first time owner w/ an oil leak
Quick Reply: New first time owner w/ an oil leak
