87 Corvette
Old Jul 15, 2018 | 10:52 AM
droptop131's Avatar
droptop131
3rd Gear
Default 87 Corvette
I have an 87 Corvette that will crank but not turn over while checking the fuses came up with .06 to the ECM fuse and after I shut off the key the horn blows once randomly can anyone help please? Thank you
Old Jul 15, 2018 | 11:21 AM
Centerline1999's Avatar
Centerline1999
You probably want to ask this question in the C-4 forum.
Old Jul 15, 2018 | 03:37 PM
See5see6's Avatar
See5see6
Ask in the C4 forum for sure, but if it's cranking, then it is turning over, right? Perhaps just not starting?
Old Jul 16, 2018 | 03:50 PM
kael's Avatar
kael
Finalist 2020 C4 of the Year - Unmodified
Start with checking the engine codes via the paperclip method. You should at least get a code 12, which indicates the ECM is probably working okay. Any more codes may indicate a related issue.
What do you mean by "not turn over"?
To 87 Corvette
