Fuse Panel Help...
Old Oct 22, 2002 | 12:22 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Fuse Panel Help...
Guys,
I wanted to add another fuse panel out under the hood for all the wires I have, mainly the WB02, heated O2, and future goodies.
Could someone explain to me what I will need to do this the *right* way.
Thanks. I am an idiot when it comes to electric stuff.
Old Oct 22, 2002 | 12:37 AM
sinistervette's Avatar
sinistervette
Default Re: Fuse Panel Help... (ski_dwn_it)
Ski,
Go down to a quality parts store(CARQUEST,NAPA,etc.) and get a "marine" fuse panel. They come in many sizes, and both styles of fuses. These are the best to use becauese they are designed to be exposed to the elaments(weather, moisture, etc.). They come marked and normally with small instructions. All you have to do is find the place you want to mount it, feed it with a supply line(min of 10ga) wire all your accessories through it, install correct fuses, and you are done. :cool: Hope this helps. :cheers:
Old Oct 22, 2002 | 12:41 AM
dtorc4's Avatar
dtorc4
If you can't find a good marine fuse panel at a parts store, go to a specialty electronics store. They will definetely have them. Tell them what kind of accessories and current draw you will be running and they should be able to help you out with the selection of specific components. Good luck. :cheers:
Old Oct 22, 2002 | 08:41 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Fuse Panel Help... (dtorc4)
How do you wire it so that it will only receive power when the key is turned? Through a relay. That is what I am unsure of.
Thanks.
Old Oct 23, 2002 | 04:55 PM
sinistervette
Thanks.
You can either use a relay or a continuos duty solenoid. The solenoid will work better because the are rated for high amounts of draw. If you use a relay make sure it is rated for at least 20-30% more load than you plan to use it for. If you use a solenoid, you will put your main(+) lead to one side of solenoid then out to the fuse panel. Then you will run a exciter (+) wire to the solenoids small terminal that will energise with the key. Then you can route your accessories. Good luck. :cheers:
To Fuse Panel Help...
