Oil temp 320 degrees!
Old Jul 20, 2018 | 10:08 PM
Mr. Magoo's Avatar
Mr. Magoo
From: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
Default Oil temp 320 degrees!
Fired up my ‘86 Vette today and noticed my Oil temp was at 320 degrees, Obviously a bad oil temp switch or faulty wire.
Is the Temp switch easy to replace and where exactly is it located?
Thanks for any help
Old Jul 21, 2018 | 11:03 AM
Mr. Magoo's Avatar
Mr. Magoo
Originally Posted by ihatebarkingdogs
Directly above the oil filter in the block. Blue wire.
Thank You!
Old Jul 21, 2018 | 11:10 AM
vader86's Avatar
vader86
Yes its above the filter, a little bit of a pain to reach it.
Old Jul 21, 2018 | 11:41 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Now THAT will get your attention!
Old Jul 21, 2018 | 12:44 PM
Mr. Magoo's Avatar
Mr. Magoo
it was an eye opener for sure. Lol!
I just had my dash rebuilt so nothing worked for years, I noticed after I plugged in the new one this problem as well as my Speedometer not working (just a zero reading).
I assume my VSS is the culprit, that should be fun to change...NOT!
To Oil temp 320 degrees!
