Security System Questions
Old Jul 23, 2018 | 11:19 PM
Lawman31's Avatar
Lawman31
Default Security System Questions
Recently while walking up to my 94, the door lock sounds like it unlockes the door, but over the past week or so it has been hit or miss amd intermittent. Now it seems like It won’t unlock the drivers door any more automatically and I need to use the key every time. I ordered a new lock motor, but don’t think this is the issue since it works perfectly with the inside switch every time.
also, I noticed that sometimes the interior lights want to stay on, even after I start the engine. I can then shut off the engine, get out, walk away, the car locks but the interior lights stay on. To fix this situation I need to put the key back in the door lock, turn to the left, then to the right to unlock and then the interior light issue seems to resolve itself.
This car is new to me, so perhaps I am doing something wrong. If you can shed some light (no pun intended) on my 2 issues with the lights and unlocking it would be greatly appreciated.
Is there a way to program the passenger door to unlock with the drivers door at the same time, or do you need to press the door button on the remote to unlock the passenger door every time?
I found this article online, but doesn’t really explain how to program the passenger door to passivly unlock. It starts to tell you, but is poorly written.
http://www.superchevy.com/how-to/vem...repair-part-1/
thx...
Old Jul 24, 2018 | 01:04 AM
Lawman31's Avatar
Lawman31
Update: I did more research online and figured out how to get the passenger door to unlock and lock while in passive mode, so thats figured out. After I programmed that, the drivers door still wasn’t unlocking. Then I used a proceedure I read about online to disable and reinable the security system alltogether by walking up to the car and then pressing the door button on the remote and waiting for the door locks to cycle. Not sure if I was able to turn the system off and back on again or not as I cycled it a few times, but when I was finished I checked things again and the drivers door opened in passive mode three times in a row. I need more time to know for sure if it’s now working, but right now I am optomistic.
feel free to chime in if what I did makes sense to you or not, or if you have any other knowledge that might be helpful.
Old Jul 24, 2018 | 08:34 AM
markKlein's Avatar
markKlein
Yes, it is almost certain that at some point you accidentally turned the PKE system "off" and that is what was causing confusion with the locking. I'm not sure about your statement about how the door lock sounds like it is unlocking the door but doesn't. You aren't trying to lock or unlock the doors by pressing the button are you? You mention passive mode, but there is only passive mode and turned off. All of the information you looked up online is spelled out in the owners manual. If you don't have one, here:
https://justgivemethedamnmanual.com/...owners-manual/
Old Jul 24, 2018 | 02:24 PM
Lawman31's Avatar
Lawman31
thanks... so far today my drivers and passenger doors are unlocking perfectly. So, yes... before as I walked up on the car I could absolutely hear the door locks click, but they were still locked when I reached for the handle prompting me to insert the key in the drivers door, turn left, then right to unlock. If I just turn to the right without turning left first, it wouldn’t unlock the door. Strange.
anyway... last evening while standing outside of the car next to the drivers door, I pressed the door button on the remote and held it down for like 2-3 seconds and would hear, “click, click” from the locks. Not sure if anything changed after that because I didn’t really test the system after. Prior to doing this I put the key in the ignition, but didn’t turn the key at all, pressed the door button on the remote for 2-3 seconds and hear the same “click, click” from the locks just like I heard when standing outside the car with no key in the ignition.
at this point I am not really sure what I did, but I accomplished both objectives, 1. Have the passenger door automatically open along with the drivers door and 2. Fix the unlock of the drivers door alltogether.
right now it all works, so I am just observing..... once I am convinced that it is actually working correctly, I may play around with the system to see how to turn it off and on etc... would be nice to disable it while I am working on the car.
any thought?
Old Jul 24, 2018 | 04:14 PM
markKlein's Avatar
markKlein
any thought?
It's working fine as you described. With the key in (not on) holding down the door button changes the settings from unlock both doors to unlock drivers door only and vice versa. Holding down the door button for a few seconds with the key out turns the system off or on. But my impression is that you are sometimes trying to push the "door" button to unlock or lock the doors, which may be contributing to your confusion. So, there is a setting to open only the drivers door, or both doors; described above.There is a setting to have the system "on" (in passive mode) or "off" (although off still means it will unlock the hatch, if you have a coupe). The only other use of the door button is to unlock the passenger door (NOT the drivers door). Trying to push the door button to lock or unlock the doors can result in accidentally turning the whole system off or on and make things very confusing. As far as the fob goes, the doors only lock and the drivers door only unlocks in the passive mode "on", you can't turn passive off and use the buttons to lock and unlock the car.
The link you posted in your first post is incorrect, in that it implies you can use the door button to unlock drivers doors or lock both doors. See pages 38-39 of the owners manual.
Old Jul 24, 2018 | 08:53 PM
Lawman31's Avatar
Lawman31
okay thanks... so before the car would unlock only the drivers door, so to open the passenger door I had to press the door button on the remote ro ulolock it. This seems like a design flaw since pressing the door button on the remote too long will turn the system off even if all you were trying to do was unlock the passenger door. Now that both doors unlock passively, I will have no reason to use the remote at all, unless I need to pop the hatch.
It workd for me all day today... I think that the system actually has three options in programming. 1. Unlock just the drivers door. 2. Unlock both doors, and 3. Don’t unlock either door as this is what it was dooing to me. Physically everything is fine, so it must be either a glitch or a programming option.
Old Jul 24, 2018 | 10:33 PM
RetroGuy's Avatar
RetroGuy
My 1996's key fob broke and was unreliable with the proximity keyless unlock feature. It became so irritating, I figured that I'd just use the door key to enter the 22 year old car. Made the car feel even more retro, and now I never have to worry if the doors unlocks as I'm walking away.
Old Jul 25, 2018 | 07:58 AM
fake's Avatar
fake
Did you change the key battery? You can test with a meter and it should be`3 volts not less. Use Duracell DL2450.
Old Jul 25, 2018 | 10:40 AM
markKlein's Avatar
markKlein
There are two separate procedures, each with only two settings, and three possible resulting states. I think of it kind of like two A/B switches. One 'switch" is unlock only drivers door or unlock both doors. The other is don't lock/unlock either door, or lock both doors and unlock the doors as indicated by the first switch. Allowing for the three results you listed (although you didn't mention the locking component). I'm not sure what you mean by "it must be either a glitch or a programming option".
As for the button unlocking the pass. door all of the time, I suspect that was incorporated after the basic design was finished because of a "I have the system set to only open the drivers door for security in parking lots, but now I am giving someone a ride home and don't want to have to walk around the car and open the pass. door with the key" concern.
Old Jul 25, 2018 | 04:30 PM
Lawman31's Avatar
Lawman31
Okay, so today the drivers door won’t unlock all the time, about 25%, it's intermittent. I understand the two settings and agree and have sucesfully programmed the system to always unlock the passenger door. Today I was able to turn the system on and off with the remote button, but each time I put it in passive mode, when it unlocks, 75% of the time only the passenger door unlocks. Seems that if I let it arm and lock and turn back really fast, the drivers door will unlock, but if I walk away and wait 10 seconds or more before walking back to the car, it unlocks, but most of the time the drivers door is still locked, so frustrating.
Just to provide more detail... the drivers door sounds like it’s unlocked everytime, the only way to tell is to grab the handle and check to see. It doesn’t sound different at all and the click is strong and solid.
anyone have any ideas? Maybe the rod in the door is just out of adjustment a little of something? But yesterday it worked all day just fine. Just very confused here.
Old Jul 26, 2018 | 05:40 PM
markKlein's Avatar
markKlein
So you are saying you walk away from the car and the horn honks and both doors lock, then you walk back to the car and hear an unlocking sound, and the passenger door is unlocked but the drivers door is still locked? And you haven't pushed any buttons, just had the fob in your pocket or something? That is really strange, I have never heard of anyone having that problem. The only thing I could even think to try would be to check and make sure the drivers side door shut switch is operating correctly.
Old Jul 26, 2018 | 06:28 PM
RWC4PHX's Avatar
RWC4PHX
Mark,
So I understand correctly, If I have the key in the ignition and press the fob button until it cycles then it should unlock both doors on my 94 when I walk up to it when in passive mode. I thought I had done this procedure but when I walk up only the drivers door unlocks and then if I press the fob once the passenger door will unlock. Not like it is a big deal but that is my **** tendencies kicking in.
Old Jul 26, 2018 | 06:44 PM
markKlein's Avatar
markKlein
Originally Posted by RWC4PHX
Mark,
Well, not quite. If you have the key in the ignition (I think it says "in but not on", not sure if it matters) and hold the door button down you should hear a clack-clack sound. That means it has changed the setting. If it was previously set to drivers door only it should now open both, if it was previously set to both it should now only open drivers door. If you do this twice (or hold the button down too long) you will be back where you started.
Old Jul 26, 2018 | 08:45 PM
Lawman31's Avatar
Lawman31
Yes, I agree... I did this process and had results as stated. Just sit in the car, place the key in the ignition without turning the key, press and hold the door button on the remote and let go after you hear the, “clack clack” from the locks. The process is the same as switching from passive to manual locking, the only thing that changes is that one of the processes has the key in the ignition and one doesn’t, the process is exactly the same.
Old Jul 26, 2018 | 08:53 PM
Lawman31's Avatar
Lawman31
Yes, you understand 100% correctly. I don’t think it’s the door pin because if you sit in the car, if the pin was the issue, leaning on the door would probably light the door ajar light on the dash, which it does not do, but I’ll check it again. I have a new door latch and lock motor, so I will tear down the door and replace both and see what happens. I bought a new latch because the plastic on the original latch has come apart and is basically not there anymore providing a metal on metal sound when closing the door. Not anything horrible, but I am a perfectionaist. I just changed out the hatch latch for the same reason, which made a huge difference. Before replacing it, it sounded like my rear window was about to break everytime I poped the hatch, now it’s like butter again the way it should be. I am empowered now since yesterday I was able to pull apart the passenger door and replace the power window motor in about 2 hours. Working on these cars isn’t that difficult if you take your time and stay organized.
Old Jul 27, 2018 | 05:00 PM
markKlein's Avatar
markKlein
Well, I think it's safe to say the PKE system is working correctly and set up the way you want. Remaining problem has to be with some component of the door itself.
Old Jul 28, 2018 | 10:31 AM
Lawman31's Avatar
Lawman31
So yesterday afternoon I tore down the drivers door and replaced the entire latch mech and installed a new lock motor. My old lock motor sounded pretty bad compared to the new one, but we’ll see. So far so good, at least for the short time I was able to test it last night, but so far everything is working as it should. Having a new latch mech is nice because my old one had the black plastics worn off completely and when you opened and closed the door, you got metal on metal feel and sound. The new one is like butter again, much nicer. The swap was a bit challenging since, even though I got a new latch that came from the same year, there were differences in the rods and other little nuances. If you ever decide you want to change out your door latch, I would recommend using the original rods and connectors that came in your car and not try and use the ones that came with the new latch.
Old Jul 28, 2018 | 03:57 PM
Lawman31's Avatar
Lawman31
So far today everything is working perfectly, fingers crossed.... I will post again if not, otherwise assume this fixed it. I will still respond to comments and questions about my experience.
To Security System Questions
