NEWBIE-OIL CHANGE QUESTION!
Old Oct 22, 2002 | 05:18 PM
bhamvett's Avatar
bhamvett
Default NEWBIE-OIL CHANGE QUESTION!
Should I wait until the oil change light come's on
or change my oil every 3000 miles?
What is the interval for the oil change
light?
The car has 32,000 miles on it if that means anything.
Thank's
bhamvett
Old Oct 22, 2002 | 05:35 PM
REW89's Avatar
REW89
Default Re: NEWBIE-OIL CHANGE QUESTION! (bhamvett)
Welcome to the fraternity!!! I change my oil AND filter every 3,000 miles, without fail. I suggest you do also, especially if you do not have a service history on the car.
Bob White
Old Oct 22, 2002 | 05:40 PM
don hall's Avatar
don hall
Your manual will explain the needed periods for oil changes, and how to reset the "change oil" light when it appears. If you do not have a manual, here are two sources: http://www.factoryautomanuals.com/ http://listings.ebaymotors.com/aw/pl...760/index.html
Old Oct 22, 2002 | 05:51 PM
Steel Blue 91's Avatar
Steel Blue 91
If YOU have not changed the oil, do it now. Use it as a baseline for service work. Repeat the LOF every 3000 miles or (and this is not mentioned too often) every three months. Rotate the tires every other oil change (unless you are running ZR1 rims). I think the oil change light will trip at about 5000 miles. Others will chime in on the above if I'm in error.
By the way, welcome and enjoy!
Old Oct 22, 2002 | 06:37 PM
Tom73's Avatar
Tom73
I change mine every 5,000 miles. Why, just easier to remember, 5/10/15/20/etc/etc. Also run Mobil 1 in all my cars.
tom...
Old Oct 22, 2002 | 06:53 PM
VetBoy89's Avatar
VetBoy89
I do mine the last weekend of every month. Why, because it's my daily driver and that equates to about 3,000 miles of commuting, not counting the weekend drives. :)
Old Oct 22, 2002 | 06:57 PM
kittmaster's Avatar
kittmaster
Every 3000 no questions no doubts. Engine is spec'd to burn 1/2 quart per 1000 miles by GM worse case, but most times never occurs, oil is the life blood of vechicle and should be taken seriously for changing it on time everytime. Seems most would agree at 3000 miles oil is no longer "clear" and should be changed as the detergents and metals begin to breakdown. Welcome!!
Old Oct 22, 2002 | 07:12 PM
WAY2FAST's Avatar
WAY2FAST
Welcome! It is kinda hard to know what 32k means since we don't know the year of your Vette, but yes please keep up with the oil changes! I have used a set of Rhino ramps with GREAT success! I use Mobil One Synthetic (even though neither it nor Syntec is truly synthetic based anymore) - I also use the Pure One filter. In any case, welcome. Tell us more about your care and WELCOME AGAIN! :D :D :D :D :D
Old Oct 23, 2002 | 08:55 AM
bhamvett's Avatar
bhamvett
Default Re: NEWBIE-OIL CHANGE QUESTION! (WAY2FAST)
Thank's for the replies!
I will change the oil every 3K with Mobile 1.
bhamvett
Old Oct 23, 2002 | 10:28 AM
bac22's Avatar
bac22
Ugh! Changing every 3000 miles is now an urban legend and all you are doing is wasting the oil. Looks like Jiffy Lube's advertising is working.
If you are using synthetic you can easily go 6000 miles. As a matter of fact Mobil 1 use to advertise 20,000 miles with their oil.
Old Oct 23, 2002 | 01:09 PM
PTz-92-LT1's Avatar
PTz-92-LT1
Default Re: NEWBIE-OIL CHANGE QUESTION! (bac22)
Every 3,000 certainly won't hurt anything but the wallet. No need with synthetic oils. I change the oil when the light comes on and currently I'm at 143,371 miles on original motor... it rarely needs any oil either...only when I really pound on it. Have went around 6,500 miles until the light went on.
Old Oct 23, 2002 | 01:17 PM
KerrLakeVette's Avatar
KerrLakeVette
6th Gear
Default Re: NEWBIE-OIL CHANGE QUESTION! (PTz-92-LT1)
I go every 5k as well in my 94 with Mobil1 and Fram filter. What's the deal with '3 months' ? Does oil go bad after 3 months in a car regardless of usage ?
Old Oct 23, 2002 | 01:44 PM
FrankLT4's Avatar
FrankLT4
I would change Mobil 1 Synthetic no more often than every 5K. Wasting money otherwise. I now do mine every 7.5K (and I'm a person who used to do every 2K on my other cars that were highway driven with regular oil).
As an experiment I determined that my oil change light comes on at around 10K, probably due mostly to easy highway miles, and a 160 degree thermostat. FrankLT4CE :seeya
Old Oct 23, 2002 | 01:45 PM
BIG JIM 54's Avatar
BIG JIM 54
I do it every 3000mi with 5-30 Mobil 1. If it's good enough for a Z06, it's good enough for my new engine. I also put a bottle of Tribotech IJP additive in at the same time. No more spun rod bearings for me.
BIG JIM
Old Oct 23, 2002 | 01:48 PM
vader86's Avatar
vader86
Filter is what needs changing at 3000mi, the Mobil 1 oil or other synthetic can go longer, up to 5000mi.
But you should get in the habit of changing it on a fixed schedule of 3k-3500mi.
Old Oct 23, 2002 | 02:27 PM
LarryK 87's Avatar
LarryK 87
Default Re: NEWBIE-OIL CHANGE QUESTION! (vader86)
the higher the quality of the filter, the higher the quality of the filtered oil, short trrips are harder on any oil so it leaves more of the job to the filter, and does not deplete the additives as fast ( but does increase the acidic contents faster). Longer trips dont help the filter much, but do help the oil a great deal ( burns off condensation etc. But also burns off the additives faster as well.the OEM filter is very small ( 1/2 qt i believe) so has a very limited filtering capability, invest in a high quality filter, and high quality synthetic oil. The higher costs are more than offset by the increased change intervals, and increased longevity of your engine.
Of course i am a bit biased towards one particular brand ( see link in sig)
also a lot of good info contained there as well.
Even for DINO oil the 3000 mile change is a myth ( it dont hurt, but just changing the filter will have the same effect).
just my 0.02 worth
Old Oct 23, 2002 | 11:10 PM
2HIP4U's Avatar
2HIP4U
Rotate your tires? How would that be done exactly?
:crazy:
To NEWBIE-OIL CHANGE QUESTION!
Old Oct 23, 2002 | 11:33 PM
vader86's Avatar
vader86
Default Re: NEWBIE-OIL CHANGE QUESTION! (2HIP4U)
if the wheels are the same size, transfer them front-back, back-front. NOT side-side
You cant do it if theyre not the same size.
Old Oct 24, 2002 | 04:17 PM
Lone Ranger's Avatar
Lone Ranger
Every 3000 is still a good idea because as the engine operates the oil recieves combustion by-products. It is not necessarily a good practice to let these combustion by-products build up too much. Filters cannot remove and hold all these wear-increasing combustion by-products.
I change every 3000 w/ Mobile 1 5W-30 and install a new K&N oil filter at each change as well. Only filters I would use would be: K&N, Mobil 1, AC UltraGuard.
Old Oct 24, 2002 | 04:31 PM
Lone Ranger
Default Re: NEWBIE-OIL CHANGE QUESTION! (BIG JIM 54)
BIG JIM
What is Tribotech IJP and what makes it special and not another snake oil?
Inquiring minds want to know :D
