Help! New Opti Installed....
Old Oct 22, 2002 | 08:59 PM
Michael21's Avatar
Michael21
Default Help! New Opti Installed....
I put a new opti spark in and everything is back together and when I start it it runs ruff for a few seconds then stalls
I've checked and everything is connected and the spark plug wires are right.
I don't know what else to look at or for.....
what'd I break now?!?!...
Old Oct 22, 2002 | 09:40 PM
hotwilzz's Avatar
hotwilzz
Default Re: Help! New Opti Installed.... (Michael21)
did you have any codes in the ecm that may need cleared by disconnecting the batt.? for the most part my experience has been plug and play. I'm sure some others will add some differant ideas
cya, david
Old Oct 22, 2002 | 09:49 PM
Michael21's Avatar
Michael21
Default Re: Help! New Opti Installed.... (hotwilzz)
I had the battery disconnected when i installed everything and I had no codes prior to that.
Old Oct 22, 2002 | 11:51 PM
republicanhunk's Avatar
republicanhunk
Another idea would be to check all your harnesses for corrosion. i found with mine that it would cause all kinds of mischeif.
Old Oct 22, 2002 | 11:55 PM
bogus's Avatar
bogus
I am assuming you have enough gas in the tank... stupid, I know...
Old Oct 23, 2002 | 01:03 AM
Michael21's Avatar
Michael21
Default Re: Help! New Opti Installed.... (bogus)
not stupid...I just went out and checked..lol
I've also unplugged and inspected all the electrical connections that i had off and nothing looks corroded or broken or anything
Old Oct 23, 2002 | 01:33 PM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
Mine did that too when I replaced my Opti and H2O pump -- turned out that I had forgotten to plug the MAF back in! :jester Check all electrical connections again!
Old Oct 23, 2002 | 07:57 PM
Michael21's Avatar
Michael21
Default Re: Help! New Opti Installed.... (94vette)
I've checked everything and it's all connected and what not
the motor turns over like it should with the coil inpluged but plug it in and it sounds like it's miss firing and out of time or something
Could I have messed up something installing the new opti?
Theres only one way for it to go on and it is lined up right on the gear pin... Could something be wrong with the new opti? or could it be the wrong part? (if that possible?)
Old Oct 23, 2002 | 08:38 PM
ittlfly's Avatar
ittlfly
Another stupid question, but have you rechecked for any codes since the installation?
Old Oct 23, 2002 | 08:44 PM
StealDads67's Avatar
StealDads67
Default Re: Help! New Opti Installed.... (ittlfly)
Make sure the opti is flush.... This can cause the problem
Old Oct 23, 2002 | 10:10 PM
bogus's Avatar
bogus
Default Re: Help! New Opti Installed.... (StealDads67)
isn't it possible to install the opti 180* out of time???
Old Oct 24, 2002 | 05:43 PM
Michael21's Avatar
Michael21
How could that happen? It only fits on one way as far as I know
It's still not running so I guess i'm gonna take it apart again and take the opti off again and see if I find anything... who knows
Old Oct 24, 2002 | 06:39 PM
fullboogie
How about improper routing of the spark plug wires?
Old Oct 24, 2002 | 07:19 PM
Michael21's Avatar
Michael21
Default Re: Help! New Opti Installed.... (fullboogie)
Routing?? never thought of that
What do you mean exactly?
They were changed maybe 3 months ago and didn't really move much during the opti install so the routing of them didnt change.
What would I not want a plug wire near?
[Modified by Michael21, 11:20 PM 10/24/2002]
Old Oct 24, 2002 | 07:30 PM
fullboogie
I meant to say that if you changed the cap along with the opti, could you have switched 2 or more plug wires around? That would certainly cause it to run like crap.
Old Oct 24, 2002 | 07:43 PM
Michael21's Avatar
Michael21
The opti I put in came as one piece which is, well, everything I'm assuming, I assume that cause this is the first time i've ever seen an opti and what i took off the car looks just like the new part I put back on the car...
:lol:
Old Oct 24, 2002 | 08:28 PM
fullboogie
Michael, did you have to remove the spark plug wires from the old setup and install them on the new setup? If so, you may have put them in the wrong order.
To Help! New Opti Installed....
Old Oct 24, 2002 | 08:53 PM
ittlfly's Avatar
ittlfly
Yep!
Old Oct 24, 2002 | 11:55 PM
Michael21's Avatar
Michael21
Yes I did remove them from the old setup... and I've checked them 3 times hoping that was the problem :(
from the top down
4 5
6 3
8 7
2 1
I even refered to the pics and firing order from a haynes repair manual just to make sure
Old Oct 25, 2002 | 06:11 AM
CowboyNVette's Avatar
CowboyNVette
Could it be a bad Opti?
