383 ?
Old Oct 22, 2002 | 09:46 PM
dave g's Avatar
dave g
Default 383 ?
have a 383 with edle rpm performer heads and tpi intake both upper and lower long tube headers 1 3/4 with flowmaster exhaust. what do you think my 1/4 time should be . it a 86 vet with auto trans just trying to get a fairly close eistament
Old Oct 23, 2002 | 12:48 AM
SSLT1KID's Avatar
SSLT1KID
Default Re: 383 ? (dave g)
sounds like it should be fast. what kind of cam are you running. with the right cam that should run a 12-low 13. but that is just a guesse. also depends on tires and what-not.
Old Oct 23, 2002 | 12:53 AM
vader86's Avatar
vader86
my guess would be high 12s
You should think about replacing the TPI intake for a Superram. Are you still running the stock TC? Id go with something bigger there too, would drop you a fair bit in ET.
Old Oct 23, 2002 | 01:00 AM
GlockLT4's Avatar
GlockLT4
Default Re: 383 ? (vader86)
any 383 built right should do 12's (imho).
Old Oct 23, 2002 | 01:42 AM
gtsyellow's Avatar
gtsyellow
Default Re: 383 ? (GlockLT4)
save for a superram & converter, you will do low 12's if you do, in your case i'd guess low 13's to high 12's, once you get a feel for the racing probably high 12's. a converter and SR will knock off half a second.
Old Oct 24, 2002 | 01:18 PM
jcazin's Avatar
jcazin
Default Re: 383 ? (gtsyellow)
might as well say high 9's until you take it to a strip- otherwise, it doesn't really matter, does it?
To 383 ?
