knock sensor
Old Oct 23, 2002 | 05:33 AM
jtfrog's Avatar
jtfrog
Default knock sensor
What type of scanner is needed to test the knock scaner and what is the procedure for this test. Can you simply use a timing light and tap on the block
Old Oct 23, 2002 | 08:35 AM
Aaron71771's Avatar
Aaron71771
Default Re: knock sensor (jtfrog)
I'm not 100% sure you need a scanner to test it. I don't have the instruction in front of me, but I think you just need to tap the exaust manifold to create a "fake" knock sound then listen for a change in engine RPM.
Old Oct 23, 2002 | 10:45 AM
Quick1's Avatar
Quick1
You can test the actual knock sensor two ways, 1-with a scanner(i have a Snap-On) hooked up,engine running,tap on the block near the sensor and watch for knock and timing retard. 2-unplug the sensor,hook a digital volt meter,set to AC, to the sensor(one end to the sensor terminal-and one end to a good ground) and read the changes! :confused:
To knock sensor
