base timming
Old Oct 23, 2002 | 05:40 AM
jtfrog's Avatar
jtfrog
Default base timming
Can the base timing be set on an 86 vette. If so i understand it is in the throttle body drivers side. If the plug has never been removed can i asume the bas idle is ok.
Old Oct 23, 2002 | 06:22 AM
gtsyellow's Avatar
gtsyellow
Default Re: base timming (jtfrog)
base timing is set by unplugging your spark advance, it's by the ecu under the hood on late C4's i have no idea where it is on early but i'm sure someone does. you then twist the distributor till the timing light flashes 6deg BTDC. timing is now set.
Old Oct 24, 2002 | 02:08 AM
vettl83's Avatar
vettl83
Default Re: base timming (gtsyellow)
Brown/tan wire coming out of the fire wall on the drivers side. Take care when unplugging it, as the connector does get brittle from under hood temps. 84 CF 91 ZR-1
Old Oct 24, 2002 | 02:40 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Base idle is set with the screw on the left side of the TB; base ignition timing is set by openinng the EST connector in the blk/tan wire and adjusting the dist position.
Old Oct 24, 2002 | 03:01 AM
ColinOpseth's Avatar
ColinOpseth
Default Re: base timming (65Z01)
here are a couple of articles I wrote on setting ignition timing.. pardon the bad links, i still haven't finished updating my articles after my website upgrade..
Setting timing using a timing light (written for TPI vehicles): http://www.gmperformance.org/modules...artid=7&page=1
Installing a V8 distributor: http://www.gmperformance.org/modules...artid=8&page=1
To base timming
