'96 Headlight motor assembly problem
Old Aug 9, 2018 | 10:57 AM
dlt4's Avatar
dlt4
Default '96 Headlight motor assembly problem
The bushings finally wore out on both motors, so I'm replacing them. Did the first one yesterday with relative ease. Everything was going well on the second one today until I tried to put the gear/bushing assembly back in to the motor housing. It simply won't go in, as if the shaft was too big for the hole in the housing. I had some trouble getting it disassembled. When I pulled out on the shaft there was some initial play, then it hung up. Finally got it out by inserting a screwdriver into the hole in the shaft for leverage. I've run out of ideas on how to get it back in, even tried tapping it in with a hammer, to no avail.
Any ideas on what is going on?
Old Aug 9, 2018 | 12:49 PM
dlt4's Avatar
dlt4
Problem solved! A big pair of channel locks convinced it to go together
