Loose Steering Column, "84
Old Aug 10, 2018 | 01:47 PM
capg's Avatar
capg
Default Loose Steering Column, "84
Sloppy steering column and my guess is it's either loose bolts or worn pins on the steering column knuckle. In either case it's a tear down to find the issue. Did typical search for how-to's and didn't find exactly what I wanted to know, which is -Do I have to remove the steering column to replace the knuckle or can I do it with the column still in? Thanks...
