C68 Electronic Climate Control Code 02
Old Aug 11, 2018 | 01:35 PM
Carnivore's Avatar
Carnivore
Default C68 Electronic Climate Control Code 02
I have a 1990 L98 C4 Corvette with a C68 Electronic Climate Control. The system had not been working correctly so I reseated the frame grounds, installed a rebuilt programmer and head unit, and a new air mix door actuator. Currently, when the vette is started the LED above a mode button (doesn't make any difference which button selected) flashes for about 30 seconds after which the climate control system functions normally while the vette is being driven. The error code in the error display is an 02. The results from a second rebuilt programmer are the same. From the FSM I have run the diagnostics for the code 02 error. Step 1 is to disconnect the battery with the ignition off and reinstall after 15 seconds. The code does not reset. The FSM states that if the code 02 did not reset, the system is OK.
So the system is OK, but operation always results in a code 02. Anybody have any idea what is going on or what to do about it?
Old Aug 11, 2018 | 06:55 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
If memory serves code 02 is the "in car temperature sensor." Did you check that before you made those repairs?
Old Aug 11, 2018 | 07:30 PM
Carnivore's Avatar
Carnivore
From FSM the Code 02 is Temp. Door Motor Circuit Fault. The system was having a variety of other problems before the repairs and had no ability to display error code or parameter information. The Air Mix Door Actuator contains both the temperature door motor and a position feedback potentiometer (variable resistor). Parameter 34, Temperature Door Feedback, is at -153 (253) at full cold and 00 at full hot (range is 255 full hot and 00 full code). Maybe the door is not getting a full travel?
Old Aug 11, 2018 | 10:11 PM
pcolt94's Avatar
pcolt94
Bill, you have confused the error codes with the parameters that you can scan thru. A simple mistake.
This is all basically correct.
I will try to explain what's happening in simple terms. Codes 1 and 2 are set when the programmer does not like the feedback voltage in regard to the blend door position. This is usually caused by the blend door motor (and not the programmer).
There is a calibration between the full swing of each position of the door and the feedback voltage from the potentiometer inside the motor assembly. Sometimes age or water intrusion can cause a problem. If the evaporator drain is clogged, water can back up into motor and cause problems.
I
don’t think the doors jam and restrict movement.
Many people have replaced the blend door motor and solved these kind of problems. I think this is a good place to start.
Information on this is in the FSM, but actual repairs are not a walk in the park.
Old Aug 11, 2018 | 11:34 PM
Carnivore's Avatar
Carnivore
I
Thanks for the information. I have already installed a new air mix door actuator (blend door motor/potentiometer). When I start my vette the LED above a mode button flashes for about 30 seconds and then the climate control system works fine while the car is running. It seems that something is going wrong in the calibration phase. I will try to take a look at the blend door movement through the blower fan module (passenger side motor compartment by firewall) to see if I can tell if the blend door is binding. Not looking forward to replacing the air mix door actuator again, so any diagnostic suggestions are appreciated.
Old Aug 12, 2018 | 10:44 AM
pcolt94's Avatar
pcolt94
Just to go out on a limb, sometimes low Freon will cause the LED to flash. It may need a bit of Freon, just a suggestion.
Looking at the door thru the evaporator is good. But if you removed the motor you can then move the shaft with your fingers and feel any resistance. It should be real free. PIA
I would also try to reset the programmer just to see if it made any difference.
If you want to get technical, you can back probe the feedback voltage and monitor what it is to see what really going on. I spent a long time working on mine and got really deep into it. The FSM tells you the resistance range of the potentiometer but does not give you a voltage range. I measured mine and your numbers I would think should be close to yours. From cold to hot (60-90) I measured 0.9 - 4.4 volts.These numbers are dependent on whether the engine is running due to battery voltage or full voltage. But I think I did it with the engine off ??
If it makes you feel any better, my LED flashes from time to time. I check for codes, no hard failure and all works OK.
Old Aug 12, 2018 | 08:36 PM
Carnivore's Avatar
Carnivore
Thanks for the suggestion. I watched the blend door operation through the blower fan module hole. The blend door did not move at all during the calibration operation. The door was initially in the full AC position. When I set the temperature to 90 degrees at the head unit, the blend door moved to the heater position in an erratic manner; stopping and back up a couple of times. However, it did go to the full heater position. When I set the temperature to 60 degrees at the head unit, the blend door moved to the full AC position in a fairly smooth motion. Since I have tried two different programmer units with similar results, my conclusion is that my new actuator has a motor or gear problem. My next step is to replace the blend door actuator again.
Old Aug 12, 2018 | 09:58 PM
belairbrian's Avatar
belairbrian
Sometimes age or water intrusion can cause a problem. If the evaporator drain is clogged, water can back up into motor and cause problems...
I think this only happens on 94 and newer. They moved the motor to the bottom of the housing in 94. The earlier cars have a motor that's on top of the heater housing. So the OP doesn't have to worry about that but rather a PITA to get at actuator.
Old Aug 13, 2018 | 06:57 PM
Carnivore's Avatar
Carnivore
The 1990 has the blend door actuator on the top of the heater core case and requires disassembly of the passenger side dash and engine compartment blower case. I have read that some owners with older C4s have switched to the heater core cases with the blend door actuator on the bottom. I am considering doing this switch.
To C68 Electronic Climate Control Code 02
