Planning on doing some cylinder head work on my LT4 and would like to nail down the compression ratio afterward...but need specs on the current OEM LT4 head gasket.
I believe it to be .049 in compressed thickness, but do not know its diameter?
I'm thinking the Fel Pro gasket 1074 will work pretty well as its compressed is .039 and 4.125 diameter. If my calculations are right, I will go from a 10.8 to 11.1 to 1 compression with same cc head.
The Impala gasket is little too thin, but my real question is if it is able to be used on aluminum heads (no brinnelling?) as the Impala was iron headed.
