stiff gas pedal...
Old Oct 23, 2002 | 06:16 PM
Storz's Avatar
Storz
Default stiff gas pedal...
the gas pedal on my car seems to be kind stiff, its sort of hard to push at first and then once it goes, it goes lots :yesnod:, any suggestions on what could cause this or how to fix it?
Old Oct 23, 2002 | 06:33 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Default Re: stiff gas pedal... (Storz)
That's how its supposed to be :yesnod:
Old Oct 23, 2002 | 07:48 PM
Storz's Avatar
Storz
Default Re: stiff gas pedal... (NUckINg FuTS)
gotcha :lol:
Old Oct 23, 2002 | 08:28 PM
DougSilver's Avatar
DougSilver
Sounds like something is binding and once you put on enough pressure to unbind, of course you are really putting your foot into it. Is something bent or rubbing?
Old Oct 23, 2002 | 08:33 PM
ittlfly's Avatar
ittlfly
Default Re: stiff gas pedal... (DougSilver)
Mine was that way after I had done some work on the injectors. I found that the throttle cable was not properly seated at the throttle body. Just a stupid mistake on my part. :lol: You might check it.
To stiff gas pedal...
