Switch signal for relay
Old Aug 20, 2018 | 01:57 PM
Eduardo L98 1991's Avatar
Eduardo L98 1991
Default Switch signal for relay
Hi,
please help me with this
Where can I took a 12v signal from switch for a relay ?
thanks in advance
Old Aug 20, 2018 | 02:03 PM
Factoid's Avatar
Factoid
Why don’t you connect it (relay pin 86) to the same 12v source you are using for pin 30?
Are you turning the relay on with a switch grounding pin 85? If so, the way described above is best.
Old Aug 20, 2018 | 06:30 PM
Eduardo L98 1991
Im connecting a wide band gauge
but this gauge send energy to heat the o2 sensor,
this gauges are sensible to volt variation
then want to connect directly to battery
but I need to find a source of switch signal
can be on engine bay or inside car
thanks in advance
To Switch signal for relay
