problems with my vette
Old Aug 26, 2018 | 09:36 PM
nighthawk101's Avatar
nighthawk101
4th Gear
Default problems with my vette
I have a 1994 corvette that I have a hard time starting. when its cold it will start, i can drive it for awhile and turn it off. after a few minutes I go to start it and it's hard to start. after about 2 to 3 attempts it starts but runs rough for about 5 seconds and clears up. any ldeas what it may be?
Old Aug 26, 2018 | 09:42 PM
PatternDayTrader's Avatar
PatternDayTrader
Bad injectors is what it sounds like.
Old Aug 26, 2018 | 09:53 PM
aklim's Avatar
aklim
Fuel pressure? Plugs? Wires?
Old Aug 26, 2018 | 10:40 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
I'm going to go with fuel pressure. As with Aklim, a solid tune up with plugs, wires and a check of your fuel pressure will tell you a lot. You don't mention mileage but you may need to swap out your fuel filter as a good step if your pressure is low (less than 40).
Put a gauge on your engine and report back.
Old Aug 26, 2018 | 10:47 PM
aklim's Avatar
aklim
Turn the key on and don't crank. What's the pressure? How long till it drops after you turn the key off? When you get it running what is the pressure at WOT?
Fine water mist AROUND the wires at night. Any sparks? If so, wires are bad. Engine hot, repeat misting Any sparks?
How old are the plugs? Are they the right kind per manufacturer spec?
Hopefully the opti is good
Old Aug 27, 2018 | 06:36 PM
nighthawk101
4th Gear
Just had the opti changed, haven't put any wires on since I've had it. (about 4 years). The plugs are about 2 years old. I'm going to try the fuel pressure test first , if that's alright then I'll change the plugs and wires and see what happens
Old Aug 27, 2018 | 06:37 PM
aklim's Avatar
aklim
I'd test the wires for leaks before dumping
Old Aug 27, 2018 | 06:38 PM
nighthawk101
4th Gear
Will do.
Old Aug 27, 2018 | 06:42 PM
nighthawk101
4th Gear
okay. will do
To problems with my vette
