SR users, do you know....
Old Oct 24, 2002 | 01:06 AM
sinistervette's Avatar
sinistervette
Default SR users, do you know....
how long the overal length of the runners and base are? How long are the runners themselves? Anyone have a pic of the inside of the plenum? What is the rpm range of this setup? What size is the stock tb on a SR? Is the SR recomended for use on a 350ci engine? Sorry about the length of this, I'm just really interested in the specs of this setup. THANKS.
Old Oct 24, 2002 | 01:23 AM
vader86's Avatar
vader86
Default Re: SR users, do you know.... (sinistervette)
Lingenfelter says it works on a 350+, Scorp has shown that it does and works damn good.
I believe they try to get you to get it with a 58mm TB.
Scorp has pictures of all of it.
Old Oct 24, 2002 | 01:38 AM
sinistervette
Default Re: SR users, do you know.... (vader86)
Oh yeah, he posted some base pics for comparison a while back. Scorp if you read this, would you mind posting the plenum pics if you have them?
I thought that the 58mm tb on a 350 is wrong? :confused:
Thanks vader86. :cheers:
Old Oct 24, 2002 | 09:46 AM
vader86's Avatar
vader86
Well they always market it with a 58mm is what i'm saying, I dont know for sure if the stock TB fits on it. I think i would use a 52mm or stocker with it on a 350.
Old Oct 24, 2002 | 10:42 AM
scorp508's Avatar
scorp508
I am using a 48mm, but will be bumping that up to a 52mm very soon. I am in Boston at a training class right now, I'll post the SR pics when I get home. Remind me.
Old Oct 24, 2002 | 12:25 PM
DON M's Avatar
DON M
You will lose some tip in throttle response with a 58mm on a 350. I think that even a 383 may not truly benifit, unless you really twist it up (7000rpm).
Old Oct 24, 2002 | 02:29 PM
vader86's Avatar
vader86
Default Re: SR users, do you know.... (DON M)
Yeah i agree, which is why i wonder why they always market it with a 58mm TB.
Old Oct 24, 2002 | 05:40 PM
SloRvette's Avatar
SloRvette
Cruise-In VII Veteran
Well the openings in the plenum are 58mm. Most people find the larger throttle bodies more responsive. Smaller throttle movements allow more air flow with the larger throttlebody. Chip programing might be the reason behind the poor throttle response problems. Not enough fuel for the increased air flow with smaller TPS changes.
Old Oct 24, 2002 | 07:50 PM
tpi 421 vette's Avatar
tpi 421 vette
Default Re: SR users, do you know.... (SloRvette)
I agree, I went from a 58mm to a monoblade. After retuning the ecm, it was noticeably more responsive.
Old Oct 25, 2002 | 12:28 AM
sinistervette
Default Re: (scorp508)
Hey Scorp, don't forget. :D :cheers:
Old Oct 25, 2002 | 12:34 AM
scorp508's Avatar
scorp508
Of course I can't find the others I have... gr....
Old Oct 25, 2002 | 07:35 AM
sinistervette
Scorp you are the man! :cool: What is the RPM range of the SR? Once again thanks guys! :D :cheers:
To SR users, do you know....
