Do I need a heater control valve?
John
I put a plug in the vacuum line and have not missed it at all. I used straight hose.
(The heater core will be "wet" regardless of whether coolant is flowing thru it or not.)
The cabin temperature benefits are minimal.
But the longevity of the heater core is secured by the continuous flow of water.
The biggest problem with getting "hot" vent air, is the fact that the entire heater/blower box (and 1/2 the intake plenum) is sitting inside the engine compartment....which is HOT. In fact, one huge aspect of the heater box is facing and right next to the exhaust manifold. So you blow ambient air through a box that's probably 150˚, and it's going to warm the air up...whether coolant is flowing into a radiator in an adjacent compartment of that box, or not.In my experience, if your blend air door is adjusted to close all the way, it won't make any diff to your vent temps if water is moving through your heater core or not.
About the duct work and all that.... tested things... like others, valve not necessary. That's Good, because mine is toast!
Oh! Test: Turned on Heat. Moved lever to full hot.. Good. Moved lever to cold. Good. Moved lever to middle. Good. Turned on A/C with lever in cold position. I wanted to see if there was any effect on the cold air temp. None.
John
John
John
I'd like to keep it in there, but would like for it to stay open at all time. The answer I'm hoping to hear is that it's open by default, closed when it gets engine vacuum (this means I can cap it off and it will flow through continuously).
Thanks!
I'm an AC **** and I don't imagine the 40 year old foam in the HVAC system seals as well as it once did on top of R134 so I coughed up the money
to replace mine for the sake of the best AC I could get out of it(which is pretty good). Continuous flow is likely better for the heater core in the long run
but I suspect when GM removed the valve there was some change to the HVAC system, better sealing, a higher capacity AC, something.
It's not like they just started engineering HVAC systems the week before these were made...
