Speedometer question
Old Aug 29, 2018 | 03:27 PM
TheGreek!'s Avatar
TheGreek!
Default Speedometer question
I recently scored a Dana 44 w/a 3.45 gear for my '96 that currently has a Dana 36. I'm not sure what gears are in the 36 but it isnt a 3.45. What do I need to do to make the speedometer read correctly when I put the Dana 44 in? The trans in it is a 700r4 (or is it a 4l60e?). Any help is appreciated.
Old Aug 29, 2018 | 03:35 PM
WVZR-1's Avatar
WVZR-1
4L60e will require a PCM calibration
Old Aug 30, 2018 | 08:26 AM
MatthewMiller's Avatar
MatthewMiller
Originally Posted by ihatebarkingdogs
You can use a signal conditioner. The trans sensor is fed to the ECM, the ECM then sends speed info on the grn/wht wire to several devices including CCM (speedometer and odometer), radio, HVAC. Read the install instructions, particularly with regards to affecting TCC slip calculations. There may also be issues with TCS, ABS, and active suspension as well. I don't know. WVZR is probably correct that a reprogram within the ECM is the best way, but not many people have access to the equipment, or know people that can do it.
EDIT: If you intercept the raw signal right out of the transmission, condition it, then send it on to the ECM, all systems affected by speed will be "recalibrated". So the $85 conditioner will work. Check with DakotaDigital that the SGI-5E can indeed be used to condition the raw VSS signal, but I think it can.
To add on extra details, in a 1996 the signal from the VSS (vehicle speed sensor in the tailshaft of the transmission) goes to the CCM, radio head unit (for variable volume based on road speed), the cruise control module, and the Real Time Damping module (for the variable shocks, if equipped):
I agree it would be better to recondition the signal before the PCM than after it. The PCM does use the speed info for various things, but the area where the speed accuracy is most important probably is in the control of the torque converter lockup.
The best way is indeed to update the PCM calibrations (aka get it "tuned") to re-calibrate the speedo. The bad news in a 1996 model is that in order to do this you have to buy a $400 software suite called Jet DST. Once you have that, it's simple to change the speedo calibration. It's just not cheap software.
Old Aug 30, 2018 | 10:41 AM
WVZR-1's Avatar
WVZR-1
I think it's important for the OP to research this 'locally' - There was/is a couple of locals here that do PCM - Tire RPM(Revolutions Per Mile/Axle ratio calibrations for $100 or close to that $$$. A DIY with a ERA/Conditioner I believe is much 'trial/error'and presents wiring and location of device issues. The DIY option is likely 'overkill' when only a Axle ratio/Tire RPM calibration is of interest.
*** If the OP mentioned his location I'd think there's good likelihood that someone either can or knows someone in the vicinity that could help.
Old Aug 30, 2018 | 11:24 AM
pacoW's Avatar
pacoW
If you can find a used (and reset back to factory) hypertech tuner the custom tune function allows you to change rear gear ratios.
Old Aug 30, 2018 | 12:08 PM
Z51BOB's Avatar
Z51BOB
Cruise-In II Veteran
Adjusting it in your ECM would be the best bet. One more option exists if your handy with electronics. I built a calibrator for my '85 with an Arduino Nano - couldn't find a gear to match my ZF6 to the 3.73. Works well and only costs about $10 to make. A fair amount of work, though.
Old Aug 30, 2018 | 04:55 PM
MatthewMiller
Good luck finding someone with Jet DST in his arenal. That's the only way to tune the PCM on a 96 C4 that I know (LT Edit is no longer available). The Hypertech tuner that PacoW mentioned won't work on this car.
I don't disagree with anything ihatebarkingdogs is saying, btw.
Old Aug 31, 2018 | 03:18 AM
VenkmanP's Avatar
VenkmanP
There are lots of places online that will reprogram the computer for $100-200. At the bottom end of that you'll get gear change and fan temperature change. At the top end you get fuel and spark adjustments which will generally give 10-15Hp on a stock LT1, and hopefully some 4L60E shift tuning (which is desperately needed - the stock 4L60E programming is crap).
$90 to change the gears and fans:
http://www.lt1pcmtuning.com/service/
Another well known tuner:
http://www.pcmforless.com/
To Speedometer question
