Why am I leeking oil out from under the PVC boot on the valve cover?
I have changed the PVC valve and the boot but it still leaks?
WTF, I know we are not supposed to use RTV sealer and I AM NOT GOING TO but WTF?
Re: Why am I leeking oil out from under the PVC boot on the valve cover? (blk91)
Is it a high mileage engine?....... maybe too much crankcase pressure.... or ........ a damaged valve cover?......... is it the CORRECT PCV valve?..... I have seen some applications that used different PCVs if they had different rear end gears....... not like yours might be that but could it be incorrect?.... :seeya
Re: Why am I leeking oil out from under the PVC boot on the valve cover? (vettmech)
The motor has less the 10k on it.
What would cause the valve cover to warp?
Is this a possibility?
Actually it could have a crack........they are brittle and made of magnesium :seeya
After removing the PVC boot and after closer inspection. I see that the valeve cover lip has seperated at the bind.
Time for new valve covers. :D
