Brake Issues - 90 C4
Old Sep 12, 2018 | 03:53 PM
RWDsmoke's Avatar
RWDsmoke
When I bought my 86 it had terrible brakes. The ABS cycled normally pulling out of the driveway and did work if I pushed hard enough on the pedal. I replaced the master cylinder, booster,calipers, hoses, pads and rotors. Still would not stop like it should. Finally out of frustration I pulled the ABS fuse and stood on the brake pedal with both feet at about 40mph. All four wheels locked and after the cloud of tire smoke dissipated I reinstalled the ABS fuse and drove home with great brakes. I've never had a problem since. Best guess, something was stuck in the ABS. This is not the recommended way to fix it but the point is the ABS can cause those symptoms.
redozvette's Avatar
redozvette
Originally Posted by aklim
I would NOT trust a 28 year old condom to help me avoid 18 years of fawking I get for 1 hour fawking I gave much less a 28 year old piece of rubber hose to stop me in an emergency. YMMV
Too true!
