First Corvette
Old Sep 3, 2018 | 06:26 AM
Mark Vansaw's Avatar
Mark Vansaw
8th Gear
Default First Corvette
I just bought a 1989 Corvette. I have a problem already.
The battery will not stay charged and the car doesn't have enough volts to keep the engine running. I have 11 volts, but need 12.5 to properly run engine.
Has anyone experienced this issue before? Thanks, Mark
Old Sep 3, 2018 | 07:53 AM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
Welcome to the forum Mark!!
Sounds like it's time for a new battery. Most auto parts stores can check the old one. Be sure to have it load tested.
Good Luck!
Old Sep 3, 2018 | 08:33 AM
Mark Vansaw
8th Gear
I am getting all the lights to work, just not enough power to run and now start the engine. I'm at 10 to 11 volts.
Old Sep 3, 2018 | 08:57 AM
Jstan2014's Avatar
Jstan2014
Welcome Mark. Congrats on your first Vette. I too recommend a new battery as a first step. You may also consider posting your question over in the C4 sections in case your problem goes beyond simply needing a new battery. Good luck!
Old Sep 3, 2018 | 09:26 AM
Sonny71's Avatar
Sonny71
Oldtimer
Welcome to the Forum
I see you're from Michigan, if you are taking the car off the road for the winter you'll need a battery tender (trickle charger). I would buy one now and put it on the battery if you don't have a battery charger, this way you'll have an idea as to spending $100+ for a new battery, Good luck
Remember to WAVE!
Old Sep 3, 2018 | 09:38 AM
Moved to C4 Tech/Performance.
Old Sep 3, 2018 | 09:50 AM
NickPSI's Avatar
NickPSI
Im in the same boat, Home Depot actually has a pretty good price on their group 75 batteries.
When you do it, do the Big 3 wiring upgrade too, i'm sure your grounds are ancient looking like mine. You'll hold 14 volts alot better.
Old Sep 3, 2018 | 11:07 AM
confab's Avatar
confab
This ^^^^
When your charging system is working you'll see about 14 volts at the battery when measured with a meter.
If you don't see that, you're running off the battery alone.
Get the alternator tested.. Probably a simple fix.
Old Sep 4, 2018 | 09:01 PM
racerseks's Avatar
racerseks
As pointed out, Home Depot has the best price if you're looking to get out cheap. I've dealt with this type of issue a lot! Get yourself a multi-meter for testing battery, alternator, etc. Good luck!
To First Corvette
