Need Answer Quick!!! Which Throttle Body
Old Oct 24, 2002 | 03:11 PM
Hammer's Avatar
Hammer
Default Need Answer Quick!!! Which Throttle Body
Car is getting a tune up ;) and need to get a throttle body for it, 52mm.
What are the reccomendations.
I will be ordering this tomorrow morning.
Old Oct 24, 2002 | 03:12 PM
DRAGRACR's Avatar
DRAGRACR
Default Re: Need Answer Quick!!! Which Throttle Body (Hammer)
The Holley is a nice piece, which is what I am running now. :yesnod:
Old Oct 24, 2002 | 03:13 PM
Phil DeJohn's Avatar
Phil DeJohn
Hammer, How the heck did you get all that stuff in that car ?? :lol:
Old Oct 24, 2002 | 03:23 PM
Hammer's Avatar
Hammer
Default Re: Need Answer Quick!!! Which Throttle Body (Phil DeJohn)
Phil,
:lol:
It was tight, but we put it in.
I'm so exceited about getting the car back, I hope the package works out ok.
Jim
I'll check on the holley now, keep the suggestions coming.
Old Oct 24, 2002 | 04:23 PM
92TripleBlack's Avatar
92TripleBlack
I'd either get a Holley($400), have your stock one ported to 52mm from someone like Ligenfelter or TPIS($275 +/-), or get a 54mm from Arizona Marine and Speed(sp?). Skip the Edelbrock BBK. To many people complaining about the low quality and stuck butterfly blades.
[Modified by 92TripleBlack, 3:24 PM 10/24/2002]
Old Oct 24, 2002 | 04:29 PM
lead_foot's Avatar
lead_foot
I've seen a "window switch" referenced by others. What does it do? :)
Old Oct 24, 2002 | 04:38 PM
Hammer's Avatar
Hammer
I really like the Arizona 54mm billet, but is it too much for a heads/cam?
The window switch activates the nitrous within a "window" of RPM's. On @ 3,000 and off @ 5,200 RPM's.
Keeps it from kicking on too early and damaging parts and keeps me from spraying when I bounce it off the rev limiter ;)
Old Oct 24, 2002 | 05:10 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
I have the Holley 58 and it beats the pants off my old BBK 52mm as far as quality and appearance. I would suggest going with the Holley 52mm.
Old Oct 24, 2002 | 05:17 PM
Greg Johnson's Avatar
Greg Johnson
Default Re: Need Answer Quick!!! Which Throttle Body (92TripleBlack)
I will sell you a 52mm. Bored from stock 48mm. I've never used it. $200.00. It's clean, but you might want to replace gaskets.
Greg
Old Oct 24, 2002 | 05:37 PM
STL94LT1's Avatar
STL94LT1
I'm running an Arizona Speed and Marine 52mm TB, works great.
Old Oct 24, 2002 | 06:12 PM
365ZUM's Avatar
365ZUM
Cruise-In III Veteran
Default Re: Need Answer Quick!!! Which Throttle Body (STL94LT1)
Hammer-
Definately go with the Arizona Speed and Marine!!!
They go all out on their TB's. IMO, they are better made than even the Accel's (lingenfelter). I am going with either the 54 or 58mm for my stroker when the time comes. Give them a call and they will be able to tell you whether the 54mm is justified for your setup. :cheers:
Old Oct 25, 2002 | 12:36 AM
Hammer's Avatar
Hammer
Default Re: Need Answer Quick!!! Which Throttle Body (365ZUM)
ttt, need to order in the morning.
Is the 54 too big?
To Need Answer Quick!!! Which Throttle Body
