85 cluster problem
I have a 1988 C4 that had the same issue with that digital dashboard. Bryan at BATEE.com will fix it properly and for a reasonable price. He also has the instruction on how to repair it online as well. If you are comfortable soldering PC board components you could do it yourself as Bryan will sell you the parts. Most people just send it to Bryan you will get it "fixed" once and for all.
With a Corvette it is wise to start at the battery and go to the post behind the battery where the fusible links get their power from and follow the power. There was so much corrosion on the post where the electrical connections met. I had problems with bad grounds but there were voltage losses that did not make any sense. After fixing the grounds most of my other problems fixed themselves.
From here you need to go to BATEE.com and learn about the dashboards.
Good Luck getting your Dash back in operation!
Did the cluster just not work or did it sustain internal damage?
QUOTE=ctmccloskey;1597989861]Hello do96819,
Good Luck getting your Dash back in operation![/QUOTE]
