Does Moisture Affect Dash
Old Sep 17, 2018 | 07:44 PM
rblakeney's Avatar
rblakeney
Default Does Moisture Affect Dash
I recently left the windows down on my '89 when a flash flood came up. Seats and carpet got pretty wet. I have now noticed that the Atari dash is a bit muddy/milky in spots when it was quite clear and bright before. The black areas were black but now show backlighting bleeding through. Is it permanently damaged or will it eventually dry out?
The bulbs are two years old and the thing is otherwise operating normally.
Old Sep 17, 2018 | 07:48 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
give it time.
Old Sep 17, 2018 | 10:09 PM
gpierce's Avatar
gpierce
Yes, moisture is bad for all the electronics in your car. If the carpets got fully flooded, you should remove all the carpet and let it dry out in this sun. It will mold under it if you don't. Doing this will keep the water evaporating from attacking your electronics too.
To Does Moisture Affect Dash
