Looking for advice on replacement clutch kit/upgrade
Old Sep 18, 2018 | 12:52 PM
Solderhead's Avatar
Solderhead
Default Looking for advice on replacement clutch kit/upgrade
Hello all thanks for reading.
Went with a Fidanza aluminum flywheel on my 94 coupe, I'm reading all about different clutch upgrade kits but nothing fairly recent. Does anyone have any current links to clutch kits that eliminate the dual mass flywheel? Looking at OEM/mild upgraded style clutches. Thanks to anyone that can offer info.
Old Sep 18, 2018 | 03:31 PM
dizwiz24's Avatar
dizwiz24
Fidanza flywheel is a great choice , be sure to use sprung hub type clutch and zfdoc thicker shim on trans countershaft to near eliminate any rattle noise!from getting rid of dual mass
Old Sep 19, 2018 | 04:01 AM
Solderhead's Avatar
Solderhead
Thank you for the reply. Can you provide more info on this shim? Additionally I'm having difficulty sourcing a clutch disc with the spring hub specifically for that application. I was reading that the Camaro LT1 disc would work for this application. Is this true?
Old Sep 19, 2018 | 06:43 AM
dizwiz24's Avatar
dizwiz24
SPEC or carolina clutch sells them.
someone else is going to have to answer about camaro disk.
zfdoc (email him) sells countershaft shim. He may need measurementa from your stock one first.
be sure to take off external weight (from flywheel), neutral balance your pressure plate to your fidanza flywheel , then add back on the external weight.
make sure you know where the extra weight of your stock dual mass was and make sure the external balance weight of the dual mass goes on clocked the same.
Old Sep 19, 2018 | 09:27 AM
Solderhead's Avatar
Solderhead
Thanks for the info. I should have specified I had the engine rebuilt to a 383 that's been internally balanced, which is one of the reasons I went with the fidanza wheel. I'll check into the other things as well, thanks!
Old Sep 21, 2018 | 10:29 AM
RandomTask's Avatar
RandomTask
+2 for Carolina clutch. Def get sprung variant. If you're having your motor balance, it would be extremely beneficial to have them balance to the FW as well.
When I had my LT4 balanced, it was off by 2oz from the factory (hence the bearings looking like crap at 78k miles).
To Looking for advice on replacement clutch kit/upgrade
