96 base front spring specs
Old Sep 19, 2018 | 09:14 PM
bob arrowsmith's Avatar
bob arrowsmith
Default 96 base front spring specs
I need to replace my front leaf spring on my 96, what would i have to know to get the correct one, spring rates seem to be confusing , i have found a nice used one but he does not know which rating.
Old Sep 19, 2018 | 11:50 PM
MatthewMiller's Avatar
MatthewMiller
The 96 front springs were the softest ever fitted to any C4, at 343lb/in. They are either coded as HA or JA - I'm not sure which, but both of those codes are the same spring rate.
Old Sep 19, 2018 | 11:52 PM
vettehardt's Avatar
vettehardt
From the charts I've seen posted on here before, the base spring is coded "HA" or "JA" while the Z51 spring is "FSR" code. These should be molded into the spring somewhere.
Old Sep 20, 2018 | 10:36 AM
WVZR-1's Avatar
WVZR-1
For starters the 1st visual check should be the fabrication/design. If it isn't fabricated like this on the spring pad it IS NOT A LATE C4 spring. I don't have a 'LATE' spring to show you where to look for the CODES. You haven't mentioned if your car is a coupe or a 'vert either. Does it matter? Maybe not as much as most might think but I'd maybe mention yours.
Being 'used' there's many OE/GM codes that could potentially be used. Some that come to mind so long as it constructed like the snapshot is HA, FSR, FSS and the JA mentioned. Fabrication/construction is the primary concern I believe that you need to be concerned with.
Old Sep 20, 2018 | 12:02 PM
bob arrowsmith
Default front spring
thank you all for the great info, now i feel i can get the proper spring.
Old Sep 21, 2018 | 05:46 AM
blackozvet's Avatar
blackozvet
https://www.corvetteforum.com/forums...84-96-z51.html
To 96 base front spring specs
