Service engine soon light
Old Oct 2, 2018 | 01:45 PM
mwk777's Avatar
mwk777
Default Service engine soon light
I have a 1990 convertible that has developed a service engine soon light issue. I have changed out the distributor, checked the timing and put all new spark plugs in it but it still has hesitation and poor acceleration and an intermittent service engine soon light that comes on. Any ideas on what to check next?
Old Oct 2, 2018 | 02:49 PM
JimLentz's Avatar
JimLentz
Check for codes as outlined here.
Old Oct 3, 2018 | 03:33 PM
aklim's Avatar
aklim
Check the fuel pressure, spark plug wires and scan the data from the ECM
Old Oct 3, 2018 | 05:29 PM
xrav22's Avatar
xrav22
After taking out my distributor I did not put the ICM wires all the way back on the module. It causes misfire and melted one of my wires and thru a code . check your codes for the first step
Old Oct 3, 2018 | 05:57 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I agree with pulling the codes as the next (should be first) step.
Old Oct 4, 2018 | 04:32 PM
mwk777's Avatar
mwk777
thanks for the help! Just got home and disconnected the battery and then restarted the car. The light came back on and I did the code check and came up with h43. “Electronic spark control” any ideas on this. Already Changed plugs wires and distributor
Old Oct 4, 2018 | 06:40 PM
bosshog8's Avatar
bosshog8
It appears to be knock sensor related.
File Type: pdf
Old Oct 4, 2018 | 06:45 PM
mwk777's Avatar
mwk777
funny you say that, initially it had the code for knock sensor and electronic spark. Now at idle so far only electronic spark is showing up. You think it worth just to replace the knock sensor?
Old Oct 4, 2018 | 06:49 PM
mwk777's Avatar
mwk777
the chart is awesome but a little above my abilities
Old Oct 5, 2018 | 08:50 PM
mwk777's Avatar
mwk777
[QUOTE=mwk777;1598103226]
Problem solved! Knock sensor wire melted and was grounding out. Spliced in new wire and no light no miss!!! Thanks for the help
To Service engine soon light
