Motor Oil
Old Oct 6, 2018 | 09:34 PM
Joe C's Avatar
Joe C
Originally Posted by Benny42
What are your cold & hot oil pressure readings? If your motor is about worn out go up a grade. If it is still making proper oil pressure on the factory recommended grade then stay with it. My car ('86L) has about 125k miles and good oil pressure on 10w30 in Texas heat. It really is up to you, these are JUST small block chevys and are kind of hard to kill unless you beat them really hard.
- in a nutshell, just follow the owners manual, and all's good.
Old Oct 6, 2018 | 09:44 PM
aklim's Avatar
aklim
Originally Posted by Joe C
not sure where you're going with this, but "for THEM," i'm guessing would only apply during the warranty period - back then, as I recall, 3 years/36K miles. since my owners manual covers maintenance up to, and sometimes exceeding 100K miles, anything outside the warranty period, they are doing for "my benefit" and what's best suited from a maintenance standpoint. not sure how the factory can even define and cover "the zenith." if they could, that would just redefine it as the norm. someone will always push the envelope and that, the manufacturer can't control. not sure i know of any oil related engine failures, outside the warranty period, due to the owner following the manufacturers recommended maintenance and maintenance schedule, so the whole thing is subjective - i really don't care who they figured it out for - them, me, or anyone else. it works for me and one less thing i have to think about. peace.
We have also wondered why we have to put in an additive every 15K for my Powerstroke which uses the regular green stuff for coolant. Is that the best idea? Well, it depends. The dealership would have to stock that coolant, which they do and the small bottles of the additive. International uses a more robust coolant which has better life and no need additives. International made that engine for trucks which Ford bought. Truck shops have ELC for other trucks. Ford dealerships might not want to stock yet another coolant for a few diesel vehicles or so a suspicious man like myself would think. Test strips International recommends show the green stuff with the additive every 15K is barely adequate.
Old Oct 6, 2018 | 11:22 PM
Joe C's Avatar
Joe C
additives, powerstroke, green stuff, international and ford trucks, ELE - sorry, I have no idea what you're talking about or why - ???
Old Oct 6, 2018 | 11:28 PM
aklim's Avatar
aklim
Sorry it's confusing you but the PRINCIPLE is that we need to be more skeptical about why something is recommended instead of simply swallowing whatever they put before us without questions.
Old Oct 6, 2018 | 11:54 PM
Joe C's Avatar
Joe C
man, I must be dense. thought the subject at hand was 10W30 vs 10W40. , some things in life you need to be skeptical of, but i'm not sure this is one of them.
Old Oct 7, 2018 | 10:33 AM
RetroGuy's Avatar
RetroGuy
Originally Posted by ihatebarkingdogs
He doesn't either. Just the usual aklim claptrap. I've had him on ignore for a long time. Makes the threads easier and more enjoyable to read because his every-other nonsense post is redacted.
HAHAHAHAAAA...Totally agree, Aklim luvs to debate anything...
Old Oct 7, 2018 | 10:46 AM
aklim's Avatar
aklim
the factory figured all this out for us. one less thing we need to worry about
. That was what I thought we were talking about. I choose not to give blind trust to anyone. I prefer to find out why when possible. Either you will pleasantly surprise me or I won't be unprepared for your treachery. I take factory recommendations as the lowest standard possible rather than the "gold" standard.
Old Oct 7, 2018 | 01:38 PM
Joe C's Avatar
Joe C
whatever makes you happy....
Old Oct 7, 2018 | 09:46 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
PLEASE HELP! Where is this "IGNORE" function? Is there a setting here I can activate? I want to do this also.
Old Oct 7, 2018 | 10:18 PM
aklim's Avatar
aklim
User CP
Scroll down to settings and options
Edit Ignore list
Add member to the list
I got to say it is a pretty good crutch for those who cannot mentally discipline themselves to do it.
Old Oct 13, 2018 | 03:15 PM
Renfield's Avatar
Renfield
User CP
Edit Ignore list
There is one poster on this thread on MY ignore list, and it isn't you.
Old Oct 15, 2018 | 09:26 PM
FOURSPEEDVETTE
Old Oct 16, 2018 | 03:59 PM
  #33
ghoastrider1's Avatar
ghoastrider1
Engine motor oil has a self life. I dont remember what it is or were you find it on the product.it doesnt last forever on a shelf.
Old Oct 16, 2018 | 04:16 PM
  #34
aklim's Avatar
aklim
In good conditions, IIRC it was some 5 years.
Old Oct 17, 2018 | 05:41 PM
  #35
QCVette's Avatar
QCVette
Active Streak: 90 Days
Shelf life has a lot of different answers.
Most dino oils seem to have a shelf life that is affected by temp extremes even in a sealed container. Extreme temps may not even be that extreme as I read one manufacturer was claiming the below freezing could change their oil. The guesstimate of about 5 years may be about right for normal inside storage.
Synthetics may be a different story. I have read similar to the dino oils to no degradation at all. Mobil 1 stated no shelf life degradation under closed container storage. My belief is that synthetics may last much longer than dino oil and with normal storage conditions may last a long time without degradation.
The more I read about oil shelf life the more confusing it gets because different manufacturers have different statements and some statements are biased toward selling more oil.
Good luck.
Old Oct 17, 2018 | 07:20 PM
  #36
Hot Rod Roy's Avatar
Hot Rod Roy
How long has that dino oil been stored underground?
Old Oct 17, 2018 | 07:24 PM
  #37
aklim's Avatar
aklim
Relevance? Is that what you are pouring into the motor?
To Motor Oil
Old Oct 17, 2018 | 08:21 PM
  #38
Joe C's Avatar
Joe C
i'm thinking it would be the additives and not the oil that has the shelf life. as I recall, the molecular structure of oil is fairly stable. that's why motor oil can be recycled, or re-refined. remove the chemical impurities, add fresh additives, and technically, it's good as new. -
Old Oct 17, 2018 | 09:43 PM
  #39
aklim's Avatar
aklim
Hence my question of whether it is similar to the oil that sat in the ground.
Old Oct 17, 2018 | 10:37 PM
  #40
84 4+3's Avatar
84 4+3
The heat cycling it gets in the crankcase for a year if you only drive it occasionally is probably much worse than it sitting sealed on a shelf and you then deciding to dump it in after a couple years... The problem as I remember it is that the additive package tends to settle out of suspension and can't be put back by shaking after a while. Synthetic or regular, it flocculates. Again, people worry about this too much. If it's 10 years old maybe, 5 I wouldn't worry about if it were unopened unless it explicitly stated an expiration date on the bottle... and even then that is to cover their tails just in case more than anything.
