Suspension question 94
Old Oct 4, 2018 | 11:35 PM
Lawman31's Avatar
Lawman31
Default Suspension question 94
73,000 miles, replaced shocks with KYB, nice ride on freeway etc... however, when I hit bumps on regular roads the car tends to skip to one side or the other a bit. I remember reading another post about specific reasons why these cars do this, but forgot what it was. I am thinking new ball joints?? The suspension is all factory with the exception of the shocks.
Old Oct 5, 2018 | 08:41 AM
radar502's Avatar
radar502
Its the stock alignment on the C-4s will let the thing go from side to side when you hit bumps ruts ECT, in the road .. Its been years scene I had fooled with a C-4 but read up on the alignment to stop this and you will pleased on the results .. Sorry I don't any more details but is easy to find .. Al C-4s have the same problem .. I have owned 4 and had them all realigned drove like a different car..
Old Oct 5, 2018 | 10:21 AM
Lawman31's Avatar
Lawman31
Okay, thanks... I’m sure it does probably need an allignment. I was going to install new ball joints and tie rod ends anyway, so I will just add an allignment at the same time.
with so many different ball joints out there, has anyone done this and can point me in the right direction on which parts to buy? I know that the front upper ball joints are secured by rivets, but seems like all the replacements are just bolted in?
Old Oct 5, 2018 | 10:59 AM
radar502's Avatar
radar502
Yes all the replacements are bolted . Do jot go with factory alignment you will be right back to were you started with the thing handling like crap .. I'll se if I can't find the alignment chart to fix your C-4 were as it will drive right ..
Old Oct 5, 2018 | 11:14 AM
radar502's Avatar
radar502
https://tech.corvettecentral.com/201...ignment-specs/ Use this guide NOT the factory set up ,you will think your in a different car .. Had 4 C-4s and used this guide you will like driving all over again .. Been their done that ..
Old Oct 5, 2018 | 07:46 PM
Lawman31's Avatar
Lawman31
Awesome, GREAT information thanks... I guess I will go with “daily driver” since I am just looking for the car to drive straight down the road in regular daily traffic.
To Suspension question 94
