93 EVAP line Question
Old Oct 5, 2018 | 09:31 AM
radar502's Avatar
radar502
Default 93 EVAP line Question
93 Corvette I keep getting Code 26 EVAP system . I found charcoal bits in line so replaced everything . Code 26 pops back on . Here is the question ,I put air pressure on the purge line at the motor and no air come out at the canister ??? From the purge valve back to the canister is there anything in the line valves ECT. The line goes behind the rocker panel and I don't want to take it off to check it out ( might have to ) . Should I be getting air out the other end ??? I thinking pinched or plugged up from the bad canister or even leaking ???? Thanks..
