vats system
Old Oct 29, 2018 | 02:58 PM
doityourself's Avatar
doityourself
Default vats system
I've got 1996 running with resister ,the vats would not let it start but with this resister across ignition circuit it starts ,resister reading 4.71 ohms can you tell what # key blank that fits [1-15] ?I'm thinking #11 that value is 4570 but the decimal point there I'm confused , thanks
Old Oct 29, 2018 | 03:20 PM
WVZR-1's Avatar
WVZR-1
Engineering/design is 4750 with min/max 4560/4960 I believe. Move your decimals!! Did you have a correct key #11 that read that value at column base? Any number of possible issues.
Old Oct 29, 2018 | 07:59 PM
doityourself
that was my trouble my key lost its diode , and not even continuity ,went to locksmith and Chevy dealer and nether could read key , I new answer before I left my house but was doublechecking about no reading on key , so ordered #11 key blank and hopes that will fix all when cut to fit ignition . thanks again
To vats system
