O2 sensor code 44
Old Nov 1, 2018 | 08:48 PM
gnj3963's Avatar
gnj3963
Default O2 sensor code 44
Hello..1984 c4...code 44 popped up..gas milaege down to 13ish...o2 sensor fuel pump fuel pressure regulator and fuel filter are all under 1 year old..The check engine light comes only on once in a while..Sometimes after 30 minutes of driving..sometimes light stays on til car is shut off other times goes out n comes back on while driving..idle seems normal at 600 rpms..checked for vacuum leaks but none found..Waited til tank was almost empty then filled tank with fresh gas and injector cleaner but still code 44 popping up...any ideas? What are the chances of a 02 sensor going bad within 10,000 miles? Any help really appreciated..
THANKS
Old Nov 2, 2018 | 09:02 AM
Eilias's Avatar
Eilias
With gas mileage that low it sure sounds like it's not reading the O2 sensor, or a faulty O2 sensor. Do you have after market headers? What brand did you replace it with? If you have a scanner that could tell you what your computer is seeing for the O2.
When I first replaced my sensor I went with Bosch sensors that went out one after the other. After warrantying them both and them failing again, I replaced them with OE AC Delco sensors and it has worked fine ever since. I know this is a small sample size, but something to think about.
Old Nov 2, 2018 | 01:38 PM
Kevova's Avatar
Kevova
Code 44 is a lean condition, the O2 is the messenger. Don't shoot the messenger. Check for vacuum leak first including along cover to base intake gasket. Also be sure injector connectors are properly seated an wires are not pinched.. If fuel filter has not been in a while might be worth changing.. If everything checks ok then try O2 sensor.
Old Nov 2, 2018 | 01:58 PM
gnj3963's Avatar
gnj3963
Thanx for the input..my 02 sensor is bosch...Time to change..thanx
Old Nov 3, 2018 | 02:16 PM
aklim's Avatar
aklim
How old is the sensor? If it is 5 years, conventional wisdom says to change it. If it is a year old, I'd scan it or you might still have the same issue.
Old Nov 12, 2018 | 11:21 AM
gnj3963's Avatar
gnj3963
Update..Bosch 02 sensor was bad..Sensor only had 5000 miles on it and under 2 years old..replaced with ac delco..problem fixed...
Old Nov 12, 2018 | 12:35 PM
aklim's Avatar
aklim
Weird. Usually they last longer than that. Long enough most people do not replace it after it loses efficiency and gets lazy
Old Nov 12, 2018 | 04:51 PM
GregMartin's Avatar
GregMartin
Sometimes the O2 sensors go bad if the engine is too rich. I had this, the spark plugs were covered in black soot but I had a code 44. I replaced the O2 sensor and the code went away but the engine was still rich. I hooked up the trusty WinALDL and found the problem. The throttle position sensor was bad; with the throttle closed it was showing 39% open so the computer just tipped more fuel in. The car now runs like a new pin.
To O2 sensor code 44
