Need LT1 Corvette ALDL related help
Old Oct 28, 2002 | 02:26 AM
madwolf's Avatar
madwolf
Default Need LT1 Corvette ALDL related help
Does anyone have the PIN assignments for the '94-'94 Corvette ALDL connector? I'm wondering if it's the same as an F-body's connector. I don't think it's different, but I just want to make sure...
Old Nov 1, 2002 | 11:54 PM
Mo_Bandy's Avatar
Mo_Bandy
Default Re: Need LT1 Corvette ALDL related help (madwolf)
Mad wolf,
They should be the same as it is an SAE standard...
OBD-1
A-Data link Ground
B-Diagnostic request
C-AIR Solenoid
D-Malfunction Indicator Lamp
E-Serial data link 160 Baud
F-Torque converter cluth Solenoid
G-Fuel Pump
H- Anti Lock Brake
I-
J-Entertainment and comfort
K-SIR Diagnostic request
L- Serial Loop (8192 baud)
M-Serial Data Link (8192 Baud)
Hope this helps,
The contectors and pins should be the same between a Y and F body, however the ECM's will probably be different...
Mo
Old Nov 2, 2002 | 03:15 AM
Nathan Plemons's Avatar
Nathan Plemons
The 94 may have the OBDII style connector even though it is OBDI.
Look here for info and the pinout for it
http://www.akmcables.com/techinfo.htm :cheers:
To Need LT1 Corvette ALDL related help
