on an `84 L-83, are the pistons forged? 160,000 miles, aside from replacing the rings are the pistons themselves ok to recycle in a new stroker rebuild? or does the piston/rod bore wear out too much to salvage them?
I'm pretty sure your pistons are forged. As long as they are in good shape and you don't go to a bigger bore I don't see why you can't use them as long as they are the type of piston you want for your compression ratio.
