Change your O2 Sensor!!!!!
Old Oct 28, 2002 | 12:05 PM
chuckster's Avatar
chuckster
Default Change your O2 Sensor!!!!!
I just changed my O2 sensor on my wifes 1990 Coupe. It has 64,000 miles on it.
I did it in 10 minutes. Drove the front up on the Rhino Ramps and slipped righ under there.
The factory Bosch replacement cost me $18 at Autozone.
I noticed before I had crappy gas mileage ( 18mpg on a 500 mile trip..)
Even instant reading were only 18 to 21...
After the install I immediately noticed a smoother idle and not quite as smelly. I put my nose right in the exhaust stream and it just smelled like hot air.. :D
I have no long term fuel mileage number to post yet but...The intantaneous showed 28-32mpg at 55mph...
:smash: :smash: :smash: :smash:
Old Oct 28, 2002 | 12:52 PM
aroulette's Avatar
aroulette
Default Re: Change your O2 Sensor!!!!! (chuckster)
Didnt I tell you. Its exciting to see such a resut from such little work.
Old Oct 28, 2002 | 01:46 PM
WhiteIce-ChicagoRoss's Avatar
REALLY, I noticed my 1996 having a real gassy heavy smelling exaust.
Old Oct 28, 2002 | 11:18 PM
Sal Collaziano's Avatar
Sal Collaziano
Can someone post instructions on how to do this on an '87? I have the same problem.. There should be a place somewhere on the net with all this info...
Old Oct 28, 2002 | 11:45 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Change your O2 Sensor!!!!! (Sal Collaziano)
I just put an L98 O2 sensor test up on my site; all it takes is a paper clip.
Old Oct 29, 2002 | 09:25 AM
PTz-92-LT1's Avatar
PTz-92-LT1
Default Re: Change your O2 Sensor!!!!! (65Z01)
Ditto...just changed mine too. Went from 18-21 MPG at 80 MPH to 24-27...and that is on a 400 mile trip.
Old Oct 29, 2002 | 09:34 AM
hngacurv's Avatar
hngacurv
I'm glad you got some good results with replacing it, but putting your nose in the exhause stream. :eek: :crazy: Glad you're still with us.
[Modified by castivers, 1:35 PM 10/29/2002]
chuckster's Avatar
chuckster
Default Re: Change your O2 Sensor!!!!! (PTz-92-LT1)
You saved $10 on that trip...One more 400 miles trip and you payed for the O2 sensor.. :D
To Change your O2 Sensor!!!!!
