'91 L98 Head Porting
Nov 12, 2018 | 12:24 PM
So here is my plans for the engine:
*-Port heads
*-2.00/1.570 LS 8mm
*-KMotion LS drop in kit
*-1.60 stainless steel rockers
*-Erson 226/234 cam w/.545 lift
*-Port upper and lower manifold, weld OEM lower
+-TPiS big runners
*-52mm throttle body
*-Headers
*-2xxx stall converter
Nov 12, 2018 | 08:26 PM
St. Jude Donor '05
Drop in kit is springs/retainers?
Like the small stem conversion, who can the guides be purchased through (2.02/1.6 for Dart)
Those heads and seats are horrible from the factory!
Nov 12, 2018 | 08:47 PM
Quote:
Originally Posted by
cuisinartvette
PEP has any guide you need, but these I'm going to use a 8mm guide liner
Picture of the KMotion kit.
Nov 13, 2018 | 11:30 AM
Related:
Lot of good information and some dyno match ups for various TPI components here:
Just a lot of good, general background links and information too. It's a good read.
http://garage.grumpysperformance.com...ith-tpi.10494/
Nov 13, 2018 | 06:34 PM
I decided for what I want to do, the OEM manifold even with big tube runners, was going to be too much work.
Decided on a TPiS manifold.
Nov 14, 2018 | 11:08 AM
Polished stainless rocker I'm using. Very nice quality vs price.
Nov 15, 2018 | 04:04 PM
Factory steel guides cut down to .500 OD and .315 guide liners installed.
Nov 15, 2018 | 04:05 PM
Multi-angle intake valve job and radius exhaust.
Nov 16, 2018 | 08:21 PM
Nov 16, 2018 | 08:56 PM
Absolutely beautiful.. What tools are you using?
Nov 19, 2018 | 06:23 PM
Heads fitted with LS hardware.
Nov 20, 2018 | 05:03 PM
Nov 20, 2018 | 05:55 PM
Very nice.. What tools are you using to finish that? Carbide cutters and sanding rolls?
I've got a plenum and some runner that I'm going to port match and smooth out, and I want it to look exactly like yours when it is done.
Nov 20, 2018 | 05:59 PM
I use a SE5 aluma burr on everything.
Nov 20, 2018 | 07:08 PM
Some damn good numbers. How is the velocity on those ports if you mind my asking?
Nov 20, 2018 | 09:49 PM
It's almost a shame to cover up something that pretty..
Nov 21, 2018 | 04:27 PM
Nov 21, 2018 | 11:30 PM
Awesome.. It's beautiful.
You ever consider becoming a forum sponsor?
Lot of guys would pay for work like that..
Nov 23, 2018 | 07:37 AM
Very nice job, they look and flow great.
Nov 23, 2018 | 08:20 PM
I see a man sharing his passion. Mr. Speiers has all the work he can handle. Thank you.
Reason: Spelling
